I'm in search of a post that can be used for the Calypso water jet. Currently using NC geomate. I would like to use Fusion CAM since we use it for our CNC. Below is a sample of the .nc code from geomate. Is there a post like this?
geometry 2 version 4 tool_diameter 0.036000 map master slew 2.846670 0.588101 select_tool 6 contour closed inside left 1 arc 2.869297 0.610728 90.000000 arc 2.598425 0.881600 360.000000 arc 2.869297 0.610728 90.000000 slew 11.114386 0.588101 contour closed inside left 1 arc 11.137014 0.610728 90.000000 arc 10.866142 0.881600 360.000000 arc 11.137014 0.610728 90.000000 slew 19.382103 0.588101 contour closed inside left 1 arc 19.404730 0.610728 90.000000 arc 19.133858 0.881600 360.000000 arc 19.404730 0.610728 90.000000 slew 27.649819 0.588101 contour closed inside left 1 arc 27.672447 0.610728 90.000000 arc 27.401575 0.881600 360.000000 arc 27.672447 0.610728 90.000000 slew 27.649819 15.543651 contour closed inside left 1 arc 27.672447 15.566278 90.000000 arc 27.401575 15.837150 360.000000 arc 27.672447 15.566278 90.000000 slew 19.382103 15.543651 contour closed inside left 1 arc 19.404730 15.566278 90.000000 arc 19.133858 15.837150 360.000000 arc 19.404730 15.566278 90.000000 slew 11.114386 15.543651 contour closed inside left 1 arc 11.137014 15.566278 90.000000 arc 10.866142 15.837150 360.000000 arc 11.137014 15.566278 90.000000 slew 2.846670 15.543651 contour closed inside left 1 arc 2.869297 15.566278 90.000000 arc 2.598425 15.837150 360.000000 arc 2.869297 15.566278 90.000000 slew 15.032000 -0.050000 contour closed outside left 0 arc 15.000000 -0.050000 90.000000 line 0.125000 -0.018000 arc 0.125000 0.125000 -90.000000 line -0.018000 16.593750 arc 0.125000 16.593750 -90.000000 line 29.875000 16.736750 arc 29.875000 16.593750 -90.000000 line 30.018000 0.125000 arc 29.875000 0.125000 -90.000000 line 15.000000 -0.018000 arc 15.000000 -0.050000 90.000000 slew 30.000000 16.718750
