Calypso water jet post
I'm in search of a post that can be used for the Calypso water jet. Currently using NC geomate. I would like to use Fusion CAM since we use it for our CNC. Below is a sample of the .nc code from geomate. Is there a post like this?
geometry 2
version 4
tool_diameter 0.036000
map master
slew 2.846670 0.588101
select_tool 6
contour closed inside left 1
arc 2.869297 0.610728 90.000000
arc 2.598425 0.881600 360.000000
slew 11.114386 0.588101
arc 11.137014 0.610728 90.000000
arc 10.866142 0.881600 360.000000
slew 19.382103 0.588101
arc 19.404730 0.610728 90.000000
arc 19.133858 0.881600 360.000000
slew 27.649819 0.588101
arc 27.672447 0.610728 90.000000
arc 27.401575 0.881600 360.000000
slew 27.649819 15.543651
arc 27.672447 15.566278 90.000000
arc 27.401575 15.837150 360.000000
slew 19.382103 15.543651
arc 19.404730 15.566278 90.000000
arc 19.133858 15.837150 360.000000
slew 11.114386 15.543651
arc 11.137014 15.566278 90.000000
arc 10.866142 15.837150 360.000000
slew 2.846670 15.543651
arc 2.869297 15.566278 90.000000
arc 2.598425 15.837150 360.000000
slew 15.032000 -0.050000
contour closed outside left 0
arc 15.000000 -0.050000 90.000000
line 0.125000 -0.018000
arc 0.125000 0.125000 -90.000000
line -0.018000 16.593750
arc 0.125000 16.593750 -90.000000
line 29.875000 16.736750
arc 29.875000 16.593750 -90.000000
line 30.018000 0.125000
arc 29.875000 0.125000 -90.000000
line 15.000000 -0.018000
slew 30.000000 16.718750
3 Comments
al.whatmough
Moving to "under review" in advance of separating out the post ideas from the general software requests. This was a batch process. So, this particular idea may still be archived.
al.whatmough
I'm having the same issue....  the native code is not required as shown above, cnc can be used as an input file for the controller, but it has some errors that can be dumped.  However, that being said, none of the post files that Autodesk offers will function on the controller at all. They write fine in Fusion but the Calypso controllers can't recognize them.  So the post has to be modified tremendously to accommodate.  I'm still working on this....  slow process!
