Turning Post for LinuxCNC?
russtuff
Message 1 of 26
russtuff
With the new update to CAM for turning in Fusion 360 I assume there are more posts on the way. I use LinuxCNC for a Grizzly G0602 I converted to CNC myself. I've been trying to use the Generic Fanuc post but so far haven't gotten any good code to try. Any idea if/when a LinuxCNC post will be released?
Thanks.
rus, making stuff
youtube.com/russtuff
Replies (25)
Message 21 of 26
The "I" value that I'm getting in the G76 is too large, and the simulation is showing passes at the proper depth.  The CAD/CAM is showing the thread peak at 5.884, which is where the profile finishing pass leaves off, but the code I'm getting has a thread peak of 6.816 so I'm cutting mostly air with the threading tool.
(1012)
(M6X1TEST)
G7
G18
G90
G21
(FACE1)
T2 M6 G43
G54
G96 D2000 S150 M3
G95
G90 G0 X16.7 Z5.
G0 Z-0.5
G1 X12.7 F0.18
X-0.8
X2.028 Z0.914 F1.
G0 X16.7
Z5.
(PROFILE1)
G96 D2000 S150 M3
G95
G0 X16.7 Z5.
Z1.49
X10.7
G1 Z-0.51 F0.18
Z-8.4
X12.68
X15.508 Z-6.986 F1.
G0 Z1.49
X8.7
G1 Z-0.51 F0.18
Z-8.4
X10.7
X13.528 Z-6.986 F1.
G0 Z1.49
X6.7
G1 Z-0.51 F0.18
Z-8.4
X8.7
X11.528 Z-6.986 F1.
G0 Z1.49
X5.247
G1 X4.7 F1.
Z-0.51 F0.18
Z-0.799
X5.933 Z-1.416
G3 X6.284 Z-1.84 I-0.424 K-0.424
G1 Z-5.96
G3 X6.102 Z-6.278 I-0.6
G1 X4.867 Z-7.265
G2 X5.154 Z-7.301 I0.166 K0.364
G3 X6.284 Z-7.9 I-0.035 K-0.599
G1 Z-8.4
X6.7
X9.528 Z-6.986 F1.
G0 Z2.197
X3.535
G1 Z0.197 F0.18
G2 X4.121 Z-0.51 I1.
G1 X5.7 Z-1.299
X8.528 Z0.115 F1.
G0 Z2.468
X1.801
G1 Z0.468 F0.18
G2 X3.374 Z-0.509 I1.
G3 X3.77 Z-0.617 I-0.085 K-0.391 F0.08
G1 X5.65 Z-1.557
G3 X5.884 Z-1.84 I-0.283 K-0.283
G1 Z-5.96
G3 X5.762 Z-6.172 I-0.4
G1 X4.332 Z-7.316
G2 X5.13 Z-7.501 I0.434 K0.415
G3 X5.884 Z-7.9 I-0.023 K-0.399
G1 Z-8.4
X8.712 Z-6.986 F1.
X9.52
G0 X16.7
Z5.
(THREAD1)
T4 M6 G43
G54
G97 S500 M3
G95
G0 X12.7 Z5.
G0 Z8.902
G76 P1 Z-6.56 I-6.816 J0.173 K0.866 R1.3 Q30 H1
G0 X12.7 Z5.
M5
M30
Message 22 of 26
I guess I wasn't understanding that I value.  I thought it was a diameter value.  It looks like that G76 code is correct.  It must be an issue with how linuxcnc expects the tool X touchoff.
Message 23 of 26
vilts
Nice that you got the G30 sorted. I've been busy with other projects, so haven't had yet time to get back to this.
The I value in G76 is a bit weird one indeed. Took me a while to understand it.
I is a thead peak offset from the drive line. But as the drive line can be whereever you say it is, I value changes accordingly.
Actual code to calculate the I value looks like this:
  var peakOffset = (getParameter("operation:outerClearance_value") * 2) - ((x * 2)+ (threadDepth * 2));
  peakOffset = (getParameter("operation:turningMode") === "outer") ? -peakOffset : peakOffset;
So it's taking the "outerClearance" and calculating from that.
I'm soon going to do 2 or 3 start internal threads, then I'll see if the code works for that case as well. At least 2-start external threads were ok.
Message 24 of 26
My post is failing.  "Unsupported drilling orientation."  I tried the tormach post and it worked.
Information: Configuration: LinuxCNC lathe postprocessor
Information: Vendor: Viljo Marrandi
Information: Posting intermediate data to 'D:\1016.ngc'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Sunday, April 16, 2017 5:10:59 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41304
Configuration path: C:\Users\Robert\AppData\Local\Autodesk\webdeploy\production\110e62f27b395d1e77f65827ad98f9392983e959\Applications\CAM360\Data\Posts\linuxcnc_lathe.cps
Include paths: C:\Users\Robert\AppData\Local\Autodesk\webdeploy\production\110e62f27b395d1e77f65827ad98f9392983e959\Applications\CAM360\Data\Posts
Configuration modification date: Monday, March 27, 2017 11:05:46 PM
Output path: D:\1016.ngc
Checksum of intermediate NC data: 8e87a802c9759cf1b7213b5d4e5bd814
Checksum of configuration: 02c394c499d502b6d5ce9c9c3d46c663
Vendor url: http://www.autodesk.com
Legal: Copyright (C) 2012-2017 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.2938
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Unsupported drilling orientation.
Error: Failed to execute configuration.
Stop time: Sunday, April 16, 2017 5:10:59 PM
Post processing failed.
Message 25 of 26
Laurens-3DTechDraw
@Anonymous what are you trying to do?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 26 of 26
I didn't use my lathe for a few months, and now for some reason I'm getting an M4 where I should have an M3 and it doesn't put in the D4000 into the G96 Line. I had to re-download the post, but I don't know what else could have changed.  When I drill I get an M3, but all the other turning tools I get M4.  I haven't changed those tools in the library at all, and the simulation shows everything in the proper orientation.
