I have been trying to get the turrent to return to the Safe home position but haven't been able to figure out of to change post.
Any help is welcome thanks
Garret
It looks like your z-home is commented out in the post.
Does your version of the controller accept G53 (machine coordinate system) inputs?
If so, try this version. This will send the machine home in X, then in Z at every toolchange.
Obviously, test very carefully before using.
Steve
That exactly what mine looks like with the code. problem is I don't want it to go all the way back to its machine Home, just looking for a way for it to post where the Home Position i set for Tool Change clearance.
Have you tried one of the newer has ST-30 turning posts in the online post library?
These have user customizable postitions for G53 X and G53 Z.
If you have a lot of edits in your current post and don’t want to start fresh, I can add in the user properties for home position tonight or tomorrow.
Steve
