- Mute
- Permalink
- Report
I am trying to edit post processor for 5axismaker which is controlled by mach3.
This machine is head-head machine the B, C axis with axis offset.( see attachment)
So, I try to setup the axis of machine from post processor
I test these two settings to generate gcode, but all of them are the same, seems setting offset for axis is no difference.
1.
if (true) {
var bAxis = createAxis({coordinate:1, table:false, axis:[0, 1, 0], offset: [0, 30.44, 0], range:[-190,190], preference:0});
var cAxis = createAxis({coordinate:2, table:false, axis:[0, 0, 1], offset: [0, 0, 57.1], range:[-360,360], preference:0 ,cyclic: properties._cyclic});
machineConfiguration = new MachineConfiguration(bAxis, cAxis);
2.
if (true) {
var bAxis = createAxis({coordinate:1, table:false, axis:[0, 1, 0], offset: [0, 0, 0], range:[-190,190], preference:0});
var cAxis = createAxis({coordinate:2, table:false, axis:[0, 0, 1], offset: [0, 0, 0], range:[-360,360], preference:0 ,cyclic: properties._cyclic});
what did I do wrong?
