Hi!
I have a small issue when post drilling cycles with different Z depth values.
let's show you an example, if there are few drilling holes with the same Z depth it is posted like this..
nice and clean.
But if the Z depth value is different ...
the post open and close the drill cycle every time.
If it is possible I would like to change the post to show the cycles like this..
X and/or Y coordenates with Z
Nacho
Solved by KrupalVala. Go to Solution.
Hi @luis_carville ,
The drilling cycle follows the following sequence of functions,
& There are other fuctions too.
You can try with create a variable and add it to the condition in the drilling cycle phase but in some cases you may get the expected output and in some you may not.
So I would suggest go with standar format method and I am not sure if your controller supports that format or not. Even if the controller supports the format, the machine may end up behaving the same way.
Hi @KrupalVala
Thanks for your answer.
I'm not sure what you mean with "try with create a variable and add it to the condition in the drilling cycle phase", I have to say that I'm not a developer so JavaScript is not part of my skills, could you please be a bit more specific?
Many Thanks.
HI @luis_carville ,
I tried it but not getting the output 🙂. Please follow the current format which is generic and working fine.
