I'am using the keyword MODEL_IMAGE in the postprocessor.
But unfortunately it opens in standard app while postprocessing.
Is there a way to create the model image without open it automatically?
Solved by denis_q. Go to Solution.
Seems that the model image is saved to the path selected in post processing dialogue rather the path selected in the 'save as' dialogue. Further 'modelImagePath' only contains the filename of the image. How to get the full path of the image file generated with
keywords = "MODEL_IMAGE";
thank you
Solved by using AutoHotkey function RegRead to read key:
HKEY_CURRENT_USER\Software\HSMWorks\HSMWorks\ui\post process dialog
and value:
output folder
from registry.
Have tried the built in function:
hasRegistryValue("HKEY_CURRENT_USER\\Software\\HSMWorks\\HSMWorks\\ui\\post process dialog\\", "output folder")
but I get an error: 'Registry path is not supported'.
Any hints?
thank you
