HSM Post Processor Forum
Siemens Sinumerik 840D - 3+2 axis CMX 70 U
2 REPLIES 2
edin_ibreljic
83 Views, 2 Replies
I am trying to generate G - code for CMX 70 U 3+2 axis using mentioned postprocessor.
Everything goes fine instead of Chip breaking cycle.
Postprocessor generated me code trough G0 and G1 moves instead of desired cycle using G73.
Is there any possibility to configure this?
2 REPLIES 2
AdamKunzo
in reply to: edin_ibreljic
Change Accumulated pecking depth to high number (higher then depth of the hole) to get the MCALL CYCLE.
Some controllers don't support accumulated pecking depth and I believe this will be the case.
If my response answers your question, please use Accept Solution button.
This works fine. Thank you very much Adam.
Technology Administrators
