I am trying to generate G - code for CMX 70 U 3+2 axis using mentioned postprocessor.
Everything goes fine instead of Chip breaking cycle.
Postprocessor generated me code trough G0 and G1 moves instead of desired cycle using G73.
Is there any possibility to configure this?
Solved by AdamKunzo. Go to Solution.
Change Accumulated pecking depth to high number (higher then depth of the hole) to get the MCALL CYCLE.
Some controllers don't support accumulated pecking depth and I believe this will be the case.
If my response answers your question, please use Accept Solution button.
