I have Optimill F80TC which is running a Siemens 808D Controller.
I have tried to use the Siemense 802 post processor that is available currently in Fusion 360, however it puts in the following lines which throw errors.
N15 G23 G0 Z0 This line causes the controller to throw an error based on exceeding the Z Axis software limit, if I comment this line out (insert ; in front of it) Then the next error I get is that the feed rate has not been set. So I have edited the file with the feedrate (setting F1349 on line N20).
After completing these two steps the file runs as expected up until the end, where is throws the same Z Axis software limit on line
N3008 G53 Z0
A public link to the file is http://a360.co/1XmN9DP
I would love any suggestions to fix this.
Solved by George-Roberts. Go to Solution.
I have removed the G53 Z0 lines and forced the feedrate to appear on the spindle speed line (the same as you edited).. Please find the new post attached, check the code carefully.
Does this give the correct results?
Cheers
Thanks!! It looks like it will do the trick, I will try running the code on the machine first up in the morning.
Hi George,
Thanks for the help, the post processor now generates output that runs!!
Of interest I went through the program and found that the feedrate value is input several times, I'm not quite sure why, but it doesn't seem to affect the performance.
Thank you
HI George, I happen to have the same machine as Chris above (Optimill F80 TC) and tried using the Modified Siemens.cps code that you supplied previously, however I still get "Block N49 axis Z software limit switch alarming out. Wondering if you have any ideas why that might occur?
I've attached the output code for reference, seems that it trips out when "N49 Z12". I have to re-home the axis to run code again.
Maybe something has changed in recent version of F360 cam that is causing this?
Any help would be greatly appreciated.
Cheers
Luke
Hey @George-Roberts,
Thanks for posting this post. When I have posted with this so far it will always skip the first hole when using a drilling cycle. I've attached a sample post for drilling, the code tells it to move to the first hole (X.5 Y-.5) at N21 then enters the MCall Cycle81 and proceeds to move to the next hole. I can get around this by manually editing the code but being forgetful I don't always remember. If you have a solution or can point me to somewhere that I can read about how to edit this directly in the post it'd be appreciated.
I'm not sure exactly where we got it, but we eventually switched to a post for Sinumerik 840D and that's been working fine.
I need your help to create a post processor for controller siemens 808D turning
Hi @Anonymous ,
It's a Turning post processors for siemens controller.
HI @Anonymous ,
We have a generic Siemens Turning & Milling post processor. You can download it from following links
