- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, is it possible to scan thru the program before getting to "onsection"... or somehow, be able to output all the angles and work offsets used in the program at the beginning of the g-code?
I need this not for simply showing the angles used, but I have some other goal with this, but I need this data. Right now I am stuck, because I think the angles and work offsets used throughout a program are discovered as the post progresses thru "onsection", therefore, it seems that it is not possible to discover these to be output at the beginning of the g-code.
I hope I explain this clearly...
Ideally, I would want to have each work offset with its corresponding angle on 1 line, but I think I can manage to format this how I need it. If at least someone can guide me for scanning thru the program ahead of time to discover all the angles and work offsets, it would be awesome!
Thanks!
