Auger on fourth axis A
dxmv
Message 1 of 1
dxmv
Hello.
I need to perform a non-trivial task with the help of HSM! In my CNC system, instead of a spindle with a milling cutter, there is a dispenser with chocolate mass... The main coordinate axis is standard XYZ and the fourth A. When the A axis rotates, the auger rotates and squeezes the chocolate mass... I need the dispenser to come to a specified point and squeeze out a measured dose of chocolate by rotating the A axis. I use the standard strategy "Contour" or "Engraving" or "Drilling" and each time I manually write the codes for the A axis... Is there any way to do this automatically?
Replies (0)
