HSM Post Processor Forum
Prolight/Intelitek 3000 CNC lathe post
3 REPLIES 3
982 Views, 3 Replies
Hi There,
I recently picked up an Intelitek 3000 CNC lathe with the original controller box as well as PCI card. Their version of the machine software is still supported (CNCbase), but I was curious if anyone is running this from code generated through Autodesk products? They claim to support Fanuc 0 G and M codes so I am wondering if the basic fanuc post should work? Haven't gotten a chance to get anything hooked up yet but figured I'd ask to see if anyone has had any experience with it.
From the user manual: "The proLIGHT Control Program, which you load onto your computer, accepts standard EIA RS-274D G&M codes that CNC machine tools recognize."
The usermanual located here also has a list of all the G and M codes supported.
Thanks for any help!
Abraham
3 REPLIES 3
skidsolo
We supply a Prolight turning post with the software.
Andrew W. Software engineer (CAM Post Processors)
in reply to: skidsolo
That is great to know, thank you!
Hi, Seeing how the post for the Prolight 3000 worked? can you send a copy as a text file?
Martin
