Prolight/Intelitek 3000 CNC lathe post
Hi There,
I recently picked up an Intelitek 3000 CNC lathe with the original controller box as well as PCI card. Their version of the machine software is still supported (CNCbase), but I was curious if anyone is running this from code generated through Autodesk products? They claim to support Fanuc 0 G and M codes so I am wondering if the basic fanuc post should work? Haven't gotten a chance to get anything hooked up yet but figured I'd ask to see if anyone has had any experience with it.
From the user manual: "The proLIGHT Control Program, which you load onto your computer, accepts standard EIA RS-274D G&M codes that CNC machine tools recognize."
The usermanual located here also has a list of all the G and M codes supported.
Thanks for any help!
Abraham
skidsolo
We supply a Prolight turning post with the software.
Andrew W. Software engineer (CAM Post Processors)
That is great to know, thank you!
Hi, Seeing how the post for the Prolight 3000 worked? can you send a copy as a text file?
Martin
