HSM Post Processor Forum
preposition befor Traori
6 REPLIES 6
iros102
407 Views, 6 Replies
I'm having issues with the standard Fusion 360  postprocessor Sinumerik 840D (siemens-840D inspection.cps) for our DMU80 eVo. The postprocessor has been adapted for our DMU80.
The problem is that during 5-axis machining, the machine positions itself simultaneously in all 5 axes (see video), which leads to crashes.
I want the machine to first preposition with the B and C axes, and only then execute the Traori command.
The challenge lies in the tilted B-axis of the machine.
I would greatly appreciate any assistance.
What i have:
; %_N_1001_MPF
WORKPIECE(,,,"BOX",112,0,-60,80,120,120,-120,-120)
G90 G94
G71
G64
G17
G0 SUPA Z-1 D0
CYCLE800()
; 2D-Kontur1
T="NCBO_D10" D1
M6
S4775 M3
G17 G90 G94
G55
CYCLE800()
TRAORI
G0 X4.602 Y184.943 Z-43.283 A3=0.024874 B3=0.999691 C3=0
M8
 What i want
; %_N_1001_MPF
G90 G94
G71
G64
G17
G0 SUPA Z-1 D0
CYCLE800()
; 2D-Kontur1
T="NCBO_D10" D1
M6
S4775 M3
G17 G90 G94
G55
G0 B119.347 C87.441 ;<-------------Prepositting
CYCLE800()
TRAORI
M8
Labels (1)
6 REPLIES 6
iros102
in reply to: iros102
Here is a Roundaxis vectors. That can be important.
Arun.rs
HI @iros102 ,
Did you checked the output with setting machine configuration in setup? this will give you the ABC axis prior to TRAORI.
Kindly check and let me know the feedback.
Regards
Arun.RS
Technical Consultant - Post Processor
iros102
in reply to: Arun.rs
@Arun.rs
Yes I have a customized postprocessor with machine configuration. I did not want to post it here.
But it doesn't do that either.
Here is my machine config
function defineMachine() {
  var useTCP = true;
  if (false) { // note: setup your machine here
    var bAxis = createAxis({coordinate:1, table:true, axis:[0.584968, -0.573504, 0.573504], range:[-6.5, 180.5], preference:1, tcp:useTCP});
    var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, -1], range:[0, 360], preference:0, tcp:useTCP});
    machineConfiguration = new MachineConfiguration(bAxis, cAxis);
    setMachineConfiguration(machineConfiguration);
    if (receivedMachineConfiguration) {
      warning(localize("The provided CAM machine configuration is overwritten by the postprocessor."));
      receivedMachineConfiguration = false; // CAM provided machine configuration is overwritten
  if (!receivedMachineConfiguration) {
    // multiaxis settings
    if (machineConfiguration.isHeadConfiguration()) {
      machineConfiguration.setVirtualTooltip(false); // translate the pivot point to the virtual tool tip for nonTCP rotary heads
    // retract / reconfigure
    var performRewinds = false; // set to true to enable the rewind/reconfigure logic
    if (performRewinds) {
      machineConfiguration.enableMachineRewinds(); // enables the retract/reconfigure logic
      safeRetractDistance = (unit == IN) ? 1 : 25; // additional distance to retract out of stock, can be overridden with a property
      safeRetractFeed = (unit == IN) ? 20 : 500; // retract feed rate
      safePlungeFeed = (unit == IN) ? 10 : 250; // plunge feed rate
      machineConfiguration.setSafeRetractDistance(safeRetractDistance);
      machineConfiguration.setSafeRetractFeedrate(safeRetractFeed);
      machineConfiguration.setSafePlungeFeedrate(safePlungeFeed);
      var stockExpansion = new Vector(toPreciseUnit(0.1, IN), toPreciseUnit(0.1, IN), toPreciseUnit(0.1, IN)); // expand stock XYZ values
      machineConfiguration.setRewindStockExpansion(stockExpansion);
    // multi-axis feedrates
    if (machineConfiguration.isMultiAxisConfiguration()) {
      machineConfiguration.setMultiAxisFeedrate(
        useTCP ? FEED_FPM : getProperty("useDPMFeeds") ? FEED_DPM : FEED_INVERSE_TIME,
        9999.99, // maximum output value for inverse time feed rates
        getProperty("useDPMFeeds") ? DPM_COMBINATION : INVERSE_MINUTES, // INVERSE_MINUTES/INVERSE_SECONDS or DPM_COMBINATION/DPM_STANDARD
        0.5, // tolerance to determine when the DPM feed has changed
        1.0 // ratio of rotary accuracy to linear accuracy for DPM calculations
    /* home positions */
machineConfiguration.setHomePositionX(toPreciseUnit(-1, MM));
machineConfiguration.setHomePositionY(toPreciseUnit(-1, MM));
machineConfiguration.setRetractPlane(toPreciseUnit(-1, MM));
iros102
Nobody an Idea?
CNC_Lee
@iros102
I offer post processor development as a service and can definitely help with this! Email me at: lee@cnclee.com if still needing assistance.
If my post answers your question, please use Accept as Solution.
CNC Lee
Fusion 360 CAM Post Processor Expert
https://linktr.ee/cnclee
iros102
up
