Post Processors 101
Post Processors 101
kamal_fouad
Message 1 of 8
Post Processors 101
kamal_fouad
ok that’s a Problem of the Post Processor Autodesk.
You can use only the G-Code NCdrive.   (Attachement)
NO, G28, G94   and so on ….
And for G2 G3 use I,J,K Parameter relative.
hOW CAN I SOLUTION THIS PROBLEM? I USE POST PROCESSOR OF DIN 66025 BUT THE TECNICHAL OF ncdrive say that i have a problem in postprocessor for that reason the machine dont do what i programmer on.
i done the program that i do for the part the technicien say that i dont use no g28, g94 and so on.... how can i change the postprocessor
Replies (7)
Message 2 of 8
George-Roberts
Can you post out a program and get the code manually modified so it can run correctly on your machine? Then just upload the modified NC code along with the original NC file and your post processor. This would show exactly what needs modifying. Please take a look here: http://forums.autodesk.com/t5/post-processors/post-processors-101/td-p/6101613
and here: http://forums.autodesk.com/t5/post-processors/help-my-post-processor-needs-to-be-edited-now-what/td-...
These should give you the information you need 🙂
Message 3 of 8
kamal_fouad
How can i modify postprocessor or G-Code they any method for do it
Message 4 of 8
Laurens-3DTechDraw
He just gave you the info for that.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 5 of 8
kamal_fouad
Yeah but i dont have the knowledge of modified G-code i am never programmer manually always i do it from inventor to solidcam, so that i dont know how can i adapted HSM CAM to my machine with DIN 66025, without using "G28, G94   and so on …."
Message 6 of 8
George-Roberts
The "and so on" makes it impossible for us to find a solution. Could you upload some of the mastercam nc files?
Message 7 of 8
kamal_fouad
kamal maslouhi a partagé un fichier OneDrive avec vous. Pour l'afficher, cliquez sur le lien ci-dessous.
[https://r1.res.office365.com/owa/prem/images/dc-generic_20.png]
nORMAL 2.nc
for example this NC file
Message 8 of 8
kamal_fouad
I upload the NC file of HSM CAM that must editting the post processor
