I did search the forum but couldn't find an answer.
We bought a Style BT1500E CNC milling machine and want to use fusion 360.
We need a compatible postprocessor. Is this available?
What info is needed to be able to make the postprocessor?
Thanks in advance!
I've never seen one of these before, done a search and they look cool though 🙂
It looks like it is a custom control on the machines? Do you have some working sample code you could share? We can then find the closest post processor for you and see what modifications are needed (if any)
Cheers
Cheers
It's a Dutch Machine builder! Have gone bankrupt a coupe of times, but they keep crawling back up. Cool machines indeed.
Think the Fanuc or RS274 are quite close.
Possibly @Anonymous has one for sale.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Thanks Laurens!
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
@Klaas1986 wrote:
Hi, Thank you for the info, I'am already in contact with CNCmachineworks. Big chance they will provide the postprocessor.
Great to hear.
They know what they are doing there and should be able to help you with programming as well if needed.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Hi Klaas.
What is your status on the postprocessor. Did it work out with CNCmachineworks?
Thanks @Klaas1986 for your nice words, we'll keep in touch. @Anonymous, let me know if we can help you.
Does your postprocessor work on the Style BT1500 ???
I'm very interested in the postprocessor because we also have a Style BT1500
Hi @hs.
You can contact me via arjan [at] cam-consult.com. I have multiple BT1500s with multiple softwareversion and multiple options running with a postprocessor for Fusion 360/Inventor HSM
Hi! I am in the procces of setting up a BT1500 now. Is there any place to get the PP for this machine?
