POST PROCESSOR FOR SIEMENS 840D sl-840DSL-71
Good Morning,
Our machine is the DMG DMU-50 ECO . The control is the SIEMENS 840D sl-840DSL-71. The software is the
NC/NCK  V04.05.05.03-HMI 04.05.05.04-SOFTWARE VERSION NCU V04.05+SP05+HF03. And we have those three problems:
  1. the indicator of the axial rotation it's alwes turned on, from the beginning of the machining till the end, eaven if we are not using the axial rotation. this happens only if in the program there are some axial rotations.
  2.  at the end of an operation with the axial rotation turned on and before the next axial rotation, spindle and the rotary table go in the resting position. we would like that only the spindle goes in the resting position. this in order to save time.
  3. the post pocessor of the thread operation it is not complete. Attached you can see the picture of the machine interface. the Thread1 named,  it's how the machine understand the postprocessor of the cam. the thread2 named one it's how it should be. as you can see there are missing and wrong parameters.
Thank you for your help
Bojan
Replies (15)
andrea.amilo
Hi @Anonymous ,
this is the parameter to define only Z as safety plane in CYCLE800 ( = 1 ) at line 664 :
    var FR = 1; // 0 = without moving to safety plane, 1 = move to safety plane only in Z, 2 = move to safety plane Z,X,Y
You could add these lines to define rotary axis in retraction only at tool change ( starting from line 1090 ) :
    if (newWorkPlane && useMultiAxisFeatures) {
      if (insertToolCall) {
        writeBlock("CYCLE800(1,\"DMG\",200000,57,0,0,0,0,0,0,0,0,1,1)");
      } else {
        writeBlock("CYCLE800()");
This is a fixed string to be added in tapping cycle ( at line 1549 ) :
        xyzFormat.format(PIT),
        xyzFormat.format(POSS),
        xyzFormat.format(SST),
        xyzFormat.format(SST1)].join(cycleSeparator) + "0,1,0,0,,1.4,,\"ISO_METRIC\",\"M6\",,1,1001002)"
    break;
Please test it carefully and let me know it works as you need.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
Hi @andrea.amilo ,
I tried to insert your suggestions in the postp  but it doesen't works. Can you take a look on it, to see if I'm doing it right?
thank you
andrea.amilo
Hi @Anonymous ,
I think you made a good job. You have just to make two small modification and your postprocessor should be ok.
Please have a look at pictures below comparing your postprocessor vs new one.
First modification :
Second modification :
Please let me know if everything is working fine. Thank you.
Andrea Amilo
HI @andrea.amilo ,
the thread it's still not ok(machine interface it's same like before the mod.), and the rotary table goes always in the resting position after every single operation..
the only thing that chenged it's the resting posizion of the spindel. she spindle use only the Z, and that's not ok for us, we would like that the spindle goes in the left upper angle of the machine usig Z and than X and Y.
here you find attached the post, i thing that I execute your suggestions in the correct way
thank you
andrea.amilo
Hi @Anonymous ,
to avoid that rotary table goes always in ( unwanted ) resting position I think you could just comment 3 lines ( from 1099 to 1101 ) :
  if (insertToolCall || newWorkOffset || newWorkPlane) {
    //*********************************************************** (bojan 10/10/19)
    // retract to safe plane
    writeRetract(Z);
      } else {
    // if (newWorkPlane && useMultiAxisFeatures) {
    //  setWorkPlane(new Vector(0, 0, 0), false); // reset working plane
To configure the move to safety plane in Z and X/Y you can define proper parameter to 2 , at line 664 :
  if (useMultiAxisFeatures) {
    var cycle800Config = getCycle800Config();
    //***********************************************************BSTUDIO ( bojan ho messo z1: 0  09/10/19) (bojan messo var FR=1 10/10/19)
    var FR = 2; // 0 = without moving to safety plane, 1 = move to safety plane only in Z, 2 = move to safety plane Z,X,Y
    var TC = properties.cycle800SwivelDataRecord;
Regarding tapping drilling cycles, it seems your modification is good or ( at least ) it seems to write a cycle as I suppose to be done.
Could you please attach here a correct tapping cycles written on the machine ? Not the picture but the mpf file edited on the machine.
Thank you.
Andrea Amilo
If I understand this code correctly you have hard coded thread type/size into post processor. This is madness! What if you want to produce different thread, lets says M10? You would still get M6 pass-though...
I apologise if my understanding of this code is incorrect. 🙂
andrea.amilo
Hi @Anonymous,
it is a fixed text set to help me to understand the complete syntax of this cycle.
As I wrote, I would need a working mpf file edited on the machine to have the proper syntax.
In my opinion we could test something like this :
xyzFormat.format(SST1)].join(cycleSeparator) + "0,1,0,0,,1.4,,\"ISO_METRIC\",,,1,1001002)"
removing any thread type/size.
Please let me know what do you think about it.
Andrea Amilo
I have miss understood that, I apologise.
Maybe this example will help you better understand how code should look:
Code posted by post processor is executable and it produces correct threads. But it is not editable on machine. Machine's programGuide (g-code editor) feeds more parameters to cycle84.
Hi @andrea.amilo,
I'm sorry  if I took so long to give you an feedback.
*When we correct the wrong and insert the missing info from the post in the machine interface it looks like this:
N865 MCALL CYCLE84(5,0,2,-12,,0,3,,1,0,450,450,0,1,0,1,6,0.12,,"ISO_METRIC","M6",,1,1001002)
*for the rotary table:
as you can see the information it's already there. Am I right?
*for the safty paln of the spindle, we have an free machine tomorrow evening so I'll try if it is ok
thank you soo much
andrea.amilo
HI @Anonymous ,
regarding movement to safety plane, you are right the lines you have highlighted are already in your postprocessor.
But you have to comment them ( // ) to avoid the movement. So :
      } else {
For tapping drilling cycles, you migth modify postprocessor in this way :
    writeBlock(
      "MCALL CYCLE84(" + [xyzFormat.format(RTP),
        xyzFormat.format(RFP),
        xyzFormat.format(SDIS),
        xyzFormat.format(DP),
        ""/*xyzFormat.format(DPR)*/,
        conditional(DTB > 0, secFormat.format(DTB)),
        xyzFormat.format(SDAC),
        ""/*xyzFormat.format(MPIT)*/,
        xyzFormat.format(SST1)].join(cycleSeparator) +  ",0,1,0,1,,,,\"ISO_METRIC\",,,1,1001002)"
    break;
It seems to make a cycle similar to your example.
Please test it carefully and let me know.
Andrea Amilo
Maybe this Sinumerik manual which describes cycle84 could help you.
Parameters 19,20,21 can be defined as empty string and machine should still open cycle without any error.
Hi @andrea.amilo
the thread interface it's still not complete. now we got this
N860 MCALL CYCLE84(5, 0, 2, -12, , 0, 3, , 1, 0, 450, 450, 0, 0, 0, 1, 6, 0.12)
Thank You
for the rest I'll try it asap
To get requested thread cycle I would advice following changes:
case "tapping-with-chip-breaking":
    if (cycle.accumulatedDepth < cycle.depth) {
      error(localize("Accumulated pecking depth is not supported for canned tapping cycles with chip breaking."));
      return;
    if (RTP > getCurrentPosition().z) {
      writeBlock(gMotionModal.format(0), zOutput.format(RTP));
    var SDAC = SDIR; // direction of rotation after end of cycle
    var MPIT = 0; // thread pitch as thread size
    var PIT = ((tool.type == TOOL_TAP_LEFT_HAND) ? -1 : 1) * tool.threadPitch; // thread pitch
    var POSS = 0; // spindle position for oriented spindle stop in cycle (in degrees)
    var SST = spindleSpeed; // speed for tapping
    var SST1 = spindleSpeed; // speed for return
    var _AXN = 0; // tool axis
    var _PTAB = 0; // must be 0
    var _TECHNO = 0; // technology settings
    var _VARI = 1; // machining type: 0 = tapping full depth, 1 = tapping partial retract, 2 = tapping full retract
    var _DAM = cycle.incrementalDepth; // incremental depth
    var _VRT = cycle.chipBreakDistance; // retract distance for chip breaking
    var _PITM = 0; // string for pitch input (not used)
    var _PITAB = 0; // string for thread table (not used)
    var _PITABA = 0; // string for selection from thread table (not used)
    var GMODE = 0; // reserved (geometrical mode)
    var DMODE = 1; // display mode
    var AMODE = 1001002; // alternate mode
    writeBlock(
        "" /*+ xyzFormat.format(DPR)*/,
        secFormat.format(DTB),
        "" /*+ xyzFormat.format(MPIT)*/,
        xyzFormat.format(SST1),
        xyzFormat.format(_AXN),
        xyzFormat.format(_PTAB),
        xyzFormat.format(_TECHNO),
        xyzFormat.format(_VARI),
        xyzFormat.format(_DAM),
        xyzFormat.format(_VRT),
        "" /* xyzFormat.format(_PITM) */,
        "" /* xyzFormat.format(_PITAB) */,
        "" /* xyzFormat.format(_PITABA) */,
        "" /* xyzFormat.format(GMODE) */,
        xyzFormat.format(DMODE),
        xyzFormat.format(AMODE)
      ].join(cycleSeparator) + ")"
    break;
it is still not working,
thank you
andrea.amilo
Hi @Anonymous ,
this is my cycle configuration and it seems to work properly :
  case "tapping":
  case "left-tapping":
  case "right-tapping":
    writeBlock(
    break;
Andrea Amilo
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
