HSM Post Processor Forum
Post processor for Linuxcnc
14 REPLIES 14
Message 1 of 15
yoshimitsuspeed
14214 Views, 14 Replies
I need a post processor for Linuxcnc. Used to be EMC2.
http://www.linuxcnc.org/
https://www.facebook.com/groups/1229995573786339/
14 REPLIES 14
Message 2 of 15
fonsecr
in reply to: yoshimitsuspeed
Choose the post called "EMC" in the post dialog.
René Fonseca
Software Architect
Message 3 of 15
Sorry, I thought this was a section specifically for fusion 360. Just realized it's for all CAM.
I need said post processor for fusion 360 and do not see it in the post dialog.
Message 4 of 15
fonsecr
I changed your profile for you so you are in the Fusion group.
I have attached the EMC post. Only included in the next release of Fusion.
René Fonseca
Software Architect
Message 5 of 15
Message 6 of 15
New question.
The Gcode is putting the tool change location on the Z at home 0 This does not work on my machine. How do I change this? Is it possible to set it same as retract or clearance height? If not then it would be fine if I could at least set it at a different height.
Message 7 of 15
yoshimitsuspeed wrote:
New question.
How you do make you machine go to his absolute zero? Which I guess is your Z at is highest position? Or is the Z zero in it's lowest position?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 8 of 15
AchimN
Normally G28 G91 Z0 or G53 G0 Z0 will let your machine move to the highest position.
Are you able to set this up into your controller?
Achim.N
Principal Technology Consultant
Message 9 of 15
in reply to: fonsecr
Hi!
Sorry, I'm new in a forum. Can you help to me where can I find a postprocessor for a new Fusion360 software?
Message 10 of 15
AchimN
Have a look here:
http://cam.autodesk.com/posts/
Achim.N
Message 11 of 15
melfio
in reply to: AchimN
I use Fusion360 on Mac. I have a 4th axis on my mill and want to make changes to the Linux CNC "EMC" postprocessor to accommodate this. I can't find it on the list on the page "http://cam.autodesk.com/posts/". Can anyone advice on where I can find and download it? (Maybe I can already find it on my computer since it seems to be installed with FUsion360..)
Best Regards
Leo Hellberg
Message 12 of 15
Tom.Hemans
in reply to: melfio
Hi @melfio,
In the Post Library, the post I believe you're looking for is called Enhanced Machine Controller (EMC)
Tom
Tom Hemans
Technical Consultant
Message 13 of 15
melfio
in reply to: Tom.Hemans
THank you!
Message 14 of 15
mandrk
in reply to: melfio
HI, i try to use this 2 PostProcesors (hsmposts) EMC and EMC2 to generate toolpath for a LinuxCNC - for plasma cutting.
I receive errors.
Are this 2 plugins ( .cps files ) just for milling?
How can create a ngc files.
This is the returnet error.
,,Information: Configuration: LinuxCNC (EMC2)
Information: Vendor: LinuxCNC
Warning: function getProgramNameAsInt does not always return a value
Warning: function getProgramNameAsString does not always return a value
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.53.0 9
Error: Waterjet, laser, and plasma cutting toolpath is not supported by the post configuration.
Failed while processing onOpen().
Error: Failed to invoke 'onOpen' in the post configuration.
Error:
Error: Failed to execute configuration.
Stop time: Sunday, December 8, 2019 1:13:29 PM
Post processing failed."
Message 15 of 15
mandrk
in reply to: mandrk
Hi, i'm back .
I use LinuxCNCPlasma_ganta.cps file from other user post
https://forums.autodesk.com/t5/hsm-post-processor-forum/linuxcnc-plasma-laser-post-processor/m-p/903...
That file must be uploaded on HSMPOSTS on Autodesk official page
Technology Administrators
