Solved by Tom.Hemans. Go to Solution.
yoshimitsuspeed wrote:
New question.
The Gcode is putting the tool change location on the Z at home 0 This does not work on my machine. How do I change this? Is it possible to set it same as retract or clearance height? If not then it would be fine if I could at least set it at a different height.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Hi!
Sorry, I'm new in a forum. Can you help to me where can I find a postprocessor for a new Fusion360 software?
I use Fusion360 on Mac. I have a 4th axis on my mill and want to make changes to the Linux CNC "EMC" postprocessor to accommodate this. I can't find it on the list on the page "http://cam.autodesk.com/posts/". Can anyone advice on where I can find and download it? (Maybe I can already find it on my computer since it seems to be installed with FUsion360..)
Best Regards
Leo Hellberg
Hi @melfio,
In the Post Library, the post I believe you're looking for is called Enhanced Machine Controller (EMC)
Tom
HI, i try to use this 2 PostProcesors (hsmposts) EMC and EMC2 to generate toolpath for a LinuxCNC - for plasma cutting.
I receive errors.
Are this 2 plugins ( .cps files ) just for milling?
How can create a ngc files.
This is the returnet error.
,,Information: Configuration: LinuxCNC (EMC2)
Information: Vendor: LinuxCNC
Warning: function getProgramNameAsInt does not always return a value
Warning: function getProgramNameAsString does not always return a value
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.53.0 9
Error: Waterjet, laser, and plasma cutting toolpath is not supported by the post configuration.
Failed while processing onOpen().
Error: Failed to invoke 'onOpen' in the post configuration.
Error:
Error: Failed to execute configuration.
Stop time: Sunday, December 8, 2019 1:13:29 PM
Post processing failed."
Hi, i'm back .
I use LinuxCNCPlasma_ganta.cps file from other user post
That file must be uploaded on HSMPOSTS on Autodesk official page
