Pierce Plasma RUR 2000 - Almost got the POST working, need your input
- Mute
- Permalink
- Report
Hi there!
Im sorry if my technical terms for POST is probably a bit off 🙂
Our school got a Pierce RUR 2000 GP ITEC Norway APC15PIERCE (PMX105 its own)
And the control unit is a PIERCE15. It operates with absolute for starting a section and then the machine wants incremental positions for the cut job.
Im trying to write a POST script for Fusion360, so we can quit using the OMNIWIN software. Several schools would benefit from this POST getting online.
Ive based this on the WinPC.nc POST file. It was the one closest i found at that time to our machine.
Ive managed to have the output text and G / M codes match so the machine accepts it.
The attached files are:
NestPlan_from_omniwin.cnc // POST file generated with proprietary OMNIWIN for reference
Pierce_POST_almost_there.cnc // My output POST file for the Pierce RUR 2000 Machine
PiercePOSTv4_backup.cps // My adapted POST generator file ive made for the Pierce RUR 2000 Machine
I had to upload the files as .nc instead of .cnc
https://pastebin.com/mLjKLxiR // Generic FANUC.cps // Ive tried to combine this with the PIERCE for getting incremental support, i do think something is still missing.
This is our machine. It only runs using the plasma cutter.
This is what the machine wants to cut when i finally managed to format the POST so the file was accepted.
Looks like this is what happens when you only feed the machine absolute values and it wants both absolute and incremental. xD I was sort of flabbergasted for a minute there!
This is what the machine wants to cut when it gets the industrial POST from the omniwin software.
Its made using the same shapes as the Pierce POST got but at different positions.
Just so i can compare the output easier.
This is what the CNC wants to cut with the generated gcode from my adapted POST processor.
The arc on the top of the doorway is the wrong way, what can cause this? I also notice that many rounded edges displays the arcs the other way. Looks like it can do complete circles, because then it will do a complete circle and doesnt care about my fumblings.
As you can see above, what the machine now gets is almost correct. The first big square is ok, the big circle is ok.
The G90 G00 start call for the door shape is down and to the left. And the machine codes put the small circle way to the left but at correct heigth.
Ive probably spent 12 hours now to get this far, and I will finish this somehow!
Hope anyone of you experts can look over the POST generator and the two generated post codes and give hints on how to correct this behaviour.
I can think of a few things next:
1. Break up arcs into more segments to se if that handles better, or linearize. But i really dont want to linearize.
2. Check if i forgot some code from the "Generic FANUC.cps" thats incremental. I dont quite understand it all yet.
3. Must be something with this onCircular missing code for incremental support
4. How should i attack the G90 G00 POST for the doorway and the small circle beeing totally off position? What could cause this.
That would be very much appericiated!
Kind regards,
Thor
