I'm using a sheetcam post which works with my router, and need a fuson 360 post to match. I have uploaded my to posts. My router uses a piston to lower the right spindle as I have 2 of them, than the z is operated with a ball screw as normal.
Solved by scottmoyse. Go to Solution.
The trick is that we can't really convert a competitor product post to a Fusion one.
We can, however, match the output.
The easiest way to get help is do the following:
That way it's easiest to make a post.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
If I knew what changes needed to me be made I would just have done it myself..... I would gladly pay as I need this ASAP.
Sorry Paul there is no time set for helping other users out with a post.
Keep in mind that these forums are mainly driven by users.
Please find my Help! My post processor needs to be edited; now what? here: https://forums.autodesk.com/t5/hsm-post-processor-forum/help-my-post-processor-needs-to-be-edited-no...
That will guide you through editting the post with help of the forum.
And find the re-sellers with post processing capabilities here: https://forums.autodesk.com/t5/hsm-post-processor-forum/hsm-post-adjustments-needed-find-your-right-...
Laurens Wijnschenk
3DTechDraw
René for Legend.
@scottmoyse @Anonymous I have tagged in the person I suggested to you yesterday to get your post done at a cost if you wont and if you are happy to go ahead with this let him know straight away.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Scott Moyse
