HSM Post Processor Forum
multiple
13 REPLIES 13
Message 1 of 14
sevenfive85
734 Views, 13 Replies
multiple
I would like my program to post out multiple offset and another set of offset when using multiple wcs ex:
P1  (This line is what i need before my work coordinate and it increment by 1 to as many work duplicates as i tell it to a max of 8)
G54.1 P100
P2
G54.1 P101
P3
G54.1 P102
anyone with knowledge of this please help. thank you
13 REPLIES 13
Message 2 of 14
We would need your post processor to see what you need to change for that.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 3 of 14
This is the post that I would like to modify. thank you taking a look at this.
Message 4 of 14
sevenfive85
in reply to: sevenfive85
anyone?
Message 5 of 14
sevenfive85
There are too many smart people on this forum to not know this answer! PLEASE HELP.   I want two offset because one would be for my work offset and the other is for my fixture offset when using multiple work coordinate.
Message 6 of 14
parobillard
Hi
Try this one
All I did is add:
writeBlock("P" + (p - 99));
AFTER line 818
Try at your own risk!
Message 7 of 14
sevenfive85
Thank u for the reply. Yes that would work but only if I use the same offset P100 every time. I am looking for a way to do this with the freedom to use any offset number.
Message 8 of 14
parobillard
what range of offset number are you using?
Also will you use the same offset multiple times in the same output, did it need to re-call ex: P1 ?
Ex:
P1
G54.1 p100
(drill1 operation)
P2
G54.1 p101
(drill1 operation)
P1
G54.1 p100
(contour operation)
P2
G54.1 p101
(contour operation)
Message 9 of 14
sevenfive85
We have multiple programmer that uses various offset from G54-G59 and G54.1 P1 -G54.1 P300. Yes I Do need it to recall the offset. The example that you have provided is the ideal changes I need.
Message 10 of 14
parobillard
Try this one then
By the way with your current post you can't use 54 to 59 it has been disabled by someone!
Message 11 of 14
sevenfive85
in reply to: parobillard
YES! It work PERFECTLY the way I need it. thank you parobillard.
Message 12 of 14
sevenfive85
thank you again for the help. I have another question regarding this.  I would like it to error out if it exceed 8 offsets?
Message 13 of 14
parobillard
There you go!
Should work!
Message 14 of 14
sevenfive85
Thank You
