HSM Post Processor Forum
Mitsubishi M80 post processor
12 REPLIES 12
Message 1 of 13
mike-macgregor
4981 Views, 12 Replies
Wondering if anyone can help me out with a post processor for the M80 Control. I am running it on a Pinnacle 3axis Milling machine.
Having issues when posting for Tapping cycles.
I managed to get it to work by modifying the post, but its a pain atm.
Any help would be greatly appreciated.
12 REPLIES 12
Message 2 of 13
I don't know the M80 control but this works for me on the M70 control. It uses E-- for tapping.
Inventor Ultimate 2023
Windows 10 Pro
Message 3 of 13
Thanks for the post, unfortunately it did not post out properly. gave me a bunch of errors and wouldn't even post.
Message 4 of 13
It works for me in IV HSM2018. I use it all the time.
Windows 10 Pro
Message 5 of 13
Maybe it doesn't work for me since we are using 2016 here.
Message 6 of 13
Can you post using the generic Mits post in the list? How about other posts?
Windows 10 Pro
Message 7 of 13
I can for the most part, the only thing so far that has given me any problems is tapping.
And I am growing tired of editing every post that has tapping in it.
Message 8 of 13
I don't have 2016 loaded anymore but I used this post with it. I have attached another copy of the post I just tested and the output. You may need to get your dealer to look at it on your end.
Windows 10 Pro
Message 9 of 13
thanks, ill try it out shortly and let you know how I make out.
Message 10 of 13
This is what it posted for a 1/2-13 tap.
Wondering if you could explain to me how it determines its feed rate, I am assuming the P is for peck, and E is tpi? what does the R value stand for?
Also is the E is tpi, will it convert Metric for me, or do I need to keep an eye out for that when I post for my metric taps?
N115 M09
N120 M01
N125 T3 M06
N130 T2
N135 S500 M03
N140 G54
N145 M08
N155 G00 X0.75 Y-0.375
N160 G43 Z0.6 H03
N170 Z0.2
N175 M03 S500
N180 G84 X0.75 Y-0.375 Z-1.25 R0.2 P0 E13
N185 G80
N190 Z0.6
N200 M09
N205 G30 G91 Z0.
N210 G30 X0. Y0.
N215 M30
Message 11 of 13
E is the TPI. The feed is synced with the spindle RPM. If you chose a metric tap it will calculate the TPI. Try it on a metric tap.
Windows 10 Pro
Message 12 of 13
N115 M09
N120 M01
N125 T3 M06
N130 T2
N135 S500 M03
N140 G54
N145 M08
N160 G43 Z0.6 H03
N170 Z0.2
N175 M03 S500
N185 G80
N190 Z0.6
N200 M09
N205 G30 G91 Z0.
N210 G30 X0. Y0.
N215 M30
Did you get this worked out? I have a M64s control, and I edited my PP to work with G95 tapping, which is superior - especially for metric.
Message 13 of 13
hi, i know iam replying to this post after several year but i need a post processor for Mitsubishi m80a for fusion 360. We will recieve our machine Doosan DNM 6700 in about 3 months. Any help would be really appreciated
