HSM Post Processor Forum
Millplus 5Axis
3 REPLIES 3
vonhoegen
260 Views, 3 Replies
Millplus 5Axis
Hello Guys,
Is it possible to say, that the machine sway negativ if i use multi axis.
The problem is that the machine run in the limits.
Best regards
Tobi
PS: actually Setting
if (true) { // note: setup your machine here
var bAxis = createAxis({coordinate:1, table:false, axis:[0, -1, 0], range:[-90, 0], preference:1});
var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[-360, 360], preference:1});
machineConfiguration = new MachineConfiguration(bAxis, cAxis);
setMachineConfiguration(machineConfiguration);
optimizeMachineAngles2(0); // TCP mode - using G141
3 REPLIES 3
KrupalVala
in reply to: vonhoegen
HI @vonhoegen ,
Use cyclic:true in the kinematic setting. It's specifies that the axis is cyclic.
For example,
cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], cyclic:true, range:[-360, 360]});
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
vonhoegen
in reply to: KrupalVala
I dit it, but the NC Code is the same.
KrupalVala
HI @vonhoegen ,
I hope you have gone through the technical FAQ. I have shared the link here.
You will get more detail about cyclic and Range in Post Processor Manual .
If you still facing any issues then please contact us. We need some more information regarding you machine.
For example,
  • Machine configuration
  • kinematic limits
  • Does your machine C-axis support cyclic (continuous) rotation?
  • Rtcp support
Krupal Vala
Technology Administrators
