Hi Folks,
Hope I'm in the right place for this.
I recently purchased a used 1997 HAAS Vf0, with A axis provisioned but disabled - using Fusion 360 Cam. after a fair bit of mashing buttons, I've managed to load a file via RS232 ( thousand moneys and typewriters scenario).
First using the generic pre next gen post, was receiving the same error as the chap in the linked post:
https://forums.autodesk.com/t5/hsm-post-processor-forum/haas-mill-post-issues/td-p/7359177
Tried changing WCS in setup to 1 resulted in the same error.
Downloaded the VF0 post linked, reloaded the file , upon cycle start the spindle will start but alarm is tripped (336 A AXIS DISABLED)
Is there a post like the one linked, but doesn't have A axis enabled? or is there a way to edit the post to remove it? or would just editing the output file, removing all G0 A0 commands ?
uploading 3 sample programs for example, 1001 is using haas A axis post, 1002 is using Haas pre ngc post and 1003 is using the Haas vf0 post
If there's any other info you need, let me know.
Cheers
Hi @dangernoodleeng ,
The post linked below should not have any A-axis.
https://cam.autodesk.com/hsmposts?p=haas
Alternatively, if you add...
aOutput.disable();
to the end of onOpen...
...or change...
@dangernoodleeng Did the information provided by @will_1 answer your question? If so, would you please use Accept Solution so that others may find this in the future? Thank you very much!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
