Error in the win-nc post double check
daniel_lyall
Mentor Mentor
daniel_lyall
A user posted on facebook that there machine was doing some silly moves it was doing a - move when it was meant to be doing a + move
As you can see in red below
1001)
(T1 D=6. CR=0. - ZMIN=-4. - flat end mill)
N10 G90
N11 G71
(2D Contour1)
(CHANGE TOOL)
N12 T1 M06 (FLAT END MILL D=6. 6MM SINGLE FLUTE ENDMILL)
N13 S2666 M03
N14 G54
N15 M08
N16 G00 X-24.6 Y16.8
N17 G00 Z-15.  Clearances Height
N18 G00 Z-5.   Retract Height
N19 G01 Z-2. F10
N20 G01 Z0.4
It should of been doing
1001)
N10 G90
N11 G71
(2D Contour1)
(CHANGE TOOL)
N13 S2666 M03
N14 G54
N15 M08
N17 G00 Z15.
N18 G00 Z5.
N19 G01 Z-2. F10
N20 G01 Z0.4
In the post the Z format was set like below on line 90
  var zFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:-1});
I changed it to
var zFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:1});
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
bob.schultz
Thank you for bringing this to our attention.  The WinPC-NC controller is generic in nature and is meant to be connected to a variety of machines.  It seems that the machine it was originally written for moved the Z-axis in the opposite direction.  We will add a property allowing for the Z-axis to be output in the normal or opposite directions.
Bob Schultz
Sr. Post Processor Developer
arno.krenslehner03
Community Visitor
Community Visitor
Hello
Is this option to invert the movement yet implemented?
Regards
bob.schultz
Yes, you can set the desired Z-axis direction using the following post property.
The latest version of the post can be downloaded from the online Post Library.
https://cam.autodesk.com/hsmposts?p=winpc-nc
Bob Schultz
