Hurco 3+2 Post
Hurco 3+2 Post
dbonetti
Hurco 3+2 Post
dbonetti
When I post with the generic Hurco post it only post 3 axis.  I have no A B or C code in the post.  My CAM has multiple tool orientations but it is not reflected in the post.  When I post to the Haas UMC 750 I get the 3 +2 code in the post.  I want to run this on a Hurco VM10Ui.  Am I doing something wrong?  Thanks
PS I am using Fusion 360
dbonetti
Bueller?  Buller?  Anyone??
I'd like to cut this part today.  Anyone have any insight on the Hurco post?
Thanks in advance.
GeorgeRoberts
If you would like A/B/C output instead of vector outputs, you will need to add your machine definition to the post processor.  Looking at your machine specifications here: http://www.hurco.com/specs/pages/machine-data-sheet.aspx?Machine=VM10Ui&Company=HEL you need to change this:
  if (false) { // note: setup your machine here
    var aAxis = createAxis({coordinate:0, table:false, axis:[1, 0, 0], range:[-360, 360], preference:1});
    var cAxis = createAxis({coordinate:2, table:false, axis:[0, 0, 1], range:[-360, 360], preference:1});
    machineConfiguration = new MachineConfiguration(aAxis, cAxis);
    setMachineConfiguration(machineConfiguration);
    optimizeMachineAngles2(0); // TCP mode
to this:
  if (true) { // note: setup your machine here
    var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-110, 30], preference:1});
    var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[-360, 360], preference:1});
That will add a machine configuration with an A (-110 > 30 deg) and C axis (-360 > 360 deg)
Hope this helps
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
dbonetti
Thanks for your reply.  I made the suggested changes and am now getting this error in the post:
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Work plane is not supported: A-180. C-180.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Tuesday, October 24, 2017 3:04:41 PM
Post processing failed.
dbonetti
  I think I figured it out.  I just needed to change the order of axis' in my CAM.  For some reason it doesn't like the order of operations.
