I develop a post pro num 1060t , almost results . I would like to know how I can view the output file hsm before post pro.
Thanks.
SEB V
You need to debug the file and you will know each and every moves and toolpath data on that file.
To know how to debug, Please click here.
Hi thanks for your answer,
i already install the Autodesk Post Processor Editor ( Visual Studio Code with the Autodesk Fusion 360 Post Processor Utility extension)
but i can't find any files .cnc on my computer after processing , where are they???
How to use Autodesk Fusion 360 Post Processor Utility. You can download/watch it from here.
Step : Select CNC file and press Ctrl+Alt+G. It will open debug file on side-window and allows you to find(Double click on NC codes) the location of Post script codes from the NC codes.
How to enable debug mode. You can download/watch it from here.
Step: Click F1, It will open the command window and choose HSM to debug Mode then select true to turn on debug mode. Now select the CNC file which you want to test and press Ctr+Atr+G., It will open a debug window.
I hope this helps
Hi ,
Thanks, for your reponse , i try as the video but i 've got this message when i do ctrl alt G
" Running the contributed command: 'HSM.postProcess' failed."
Please check whether you have latest version of Extension (Autodesk Fusion 360 Post Processor Utility) and correct CNC file extension.
And Also check with Post Executable location,
Hi ,
thanks but i can't find the solution,
I have the v3.4.0 for the Autodesk Fusion 360 Post Processor Utility
My file have the .cnc extension
The post.exe is in the correct location C:\Program Files\Autodesk\Inventor HSM 2019
this is the message
Press Ctr+Atr+G and wait for a second. If you press quickly and multiple times then it may thorugh an error.
After above solution, still, you are facing an issue then Could you please share the post processor (*.cps)file which you are using?
ok ,
this is my post pro,
it's a modification from a HASS turning to a NUM 1060 turning. It is not completely finished.
With your post, Debug working well at my end.
T
hanks,
Hello @sebastien.vandewynckel
We have created a NUM turning post. It's actually in beta state.
https://cam.autodesk.com/posts?p=num_turning
So, you can test it but use it with caution.
Check the output and run with reduced rapid feed for testing.
Don't hesitate to provide feedback for improving the post.
Regards
Hi !
I try your pp num but i can't used it .
I have this message.
The post configuration requires revision 45702 or later of the post processor which has revision 41920
thanks for jour reponse,
This simply means that your Fusion installation is outdated.
The post engine installed by the march release of Fusion is 45745.
So the post is not using the absolute latest version.
But your installation had probably not been updated for a long time, so you have a version that is too old to be able to use the post.
This can be solved by updating the software, or are you using another software?
HSMWork, or InventorCAM?
Regards.
Ive update my inventor HSM with INV_HSM_2019_ML_6_4_1_16922_Win_64Bit_dlm.sfx.exe
but it doesn't work yet.
thanks
InventorCAM 2021 is using 45729. So i think that the 2019 is "too old" .
Our problem is that InventorCAM post engine may only be updated once or twice a year.
Whereas the Fusion post engine can change every two months.
It would be possible to revert to the previous properties definition. But it require some work.
Regards
