how to view the file before post pro processing
sebastien.vandewynckel
I develop a post pro num 1060t , almost results . I would like to know how I can view the output file hsm before post pro.
Thanks.
SEB V
Replies (15)
KrupalVala
Hi @sebastien.vandewynckel ,
You need to debug the file and you will know each and every moves and toolpath data on that file.
To know how to debug, Please click here.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
Hi thanks for your answer,
i already install the Autodesk Post Processor Editor ( Visual Studio Code with the Autodesk Fusion 360 Post Processor Utility extension)
but i can't find any  files .cnc  on my computer after processing , where are they???
KrupalVala
How to use Autodesk Fusion 360 Post Processor Utility. You can download/watch it from here.
Step : Select CNC file and press  Ctrl+Alt+G. It will open debug file on side-window and allows you to find(Double click on NC codes) the location of Post script codes from the NC codes.
How to enable debug mode. You can download/watch it from here.
Step:  Click F1, It will open the command window and choose HSM to debug Mode then select true to turn on debug mode. Now select the CNC file which you want to test and press Ctr+Atr+G., It will open a debug window.
I hope this helps
Krupal Vala
Hi ,
Thanks,  for  your reponse , i try as the video but   i 've got this message when i do  ctrl alt G
  " Running the contributed command: 'HSM.postProcess' failed."
KrupalVala
Please check whether you have latest version of Extension (Autodesk Fusion 360 Post Processor Utility) and correct CNC file extension.
And Also check with Post Executable location,
C:\User\username\AppData\Local\Autodesk\webdeploy\production\(id)\Applications\CAM360
Krupal Vala
Hi ,
thanks but i can't find the solution,
I have the v3.4.0 for the Autodesk Fusion 360 Post Processor Utility
My file have the  .cnc extension
The post.exe is in the correct location C:\Program Files\Autodesk\Inventor HSM 2019
this is the message
KrupalVala
HI @sebastien.vandewynckel ,
Press Ctr+Atr+G and wait for a second. If you press quickly and multiple times then it may thorugh an error.
After above solution, still, you are facing an issue then Could you please share the post processor (*.cps)file which you are using?
Krupal Vala
ok ,
this is my post pro,
it's a modification from a HASS turning to a NUM 1060 turning. It is not completely finished.
KrupalVala
With your post, Debug working well at my end.
T
hanks,
Krupal Vala
serge.quiblier
Hello @sebastien.vandewynckel
We have created a NUM turning post. It's actually in beta state.
https://cam.autodesk.com/posts?p=num_turning
So, you can test it but use it with caution.
Check the output and run with reduced rapid feed for testing.
Don't hesitate to provide feedback for improving the post.
Regards
Serge.Q
Technical Consultant
cam.autodesk.com
Hi !
I try your pp num  but i can't used it .
I have this message.
The post configuration requires revision 45702 or later of the post processor which has revision 41920
thanks for jour reponse,
serge.quiblier
This simply means that your Fusion installation is outdated.
The post engine installed by the march release of Fusion is 45745.
So the post is not using the absolute latest version.
But your installation had probably not been updated for a long time, so you have a version that is too old to be able to use the post.
This can be solved by updating the software, or are you using another software?
HSMWork, or InventorCAM?
Regards.
Serge.Q
cam.autodesk.com
I work with HSM .
Ive update my inventor HSM with INV_HSM_2019_ML_6_4_1_16922_Win_64Bit_dlm.sfx.exe
but it doesn't work yet.
thanks
serge.quiblier
InventorCAM 2021 is using 45729. So i think that the 2019 is "too old" .
Our problem is that InventorCAM post engine may only be updated once or twice a year.
Whereas the Fusion post engine can change every two months.
It would be possible to revert to the previous properties definition. But it require some work.
Regards
Serge.Q
cam.autodesk.com
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
