How to set up a 4/5 axis machine configuration
AchimN
Community Manager Community Manager
Message 1 of 57
AchimN
Updated August 2023:
In recent versions of Fusion, we now support machine definitions in almost all of our milling post processors, which means that the machine kinematics and options can be easily defined using the Machine Definition dialog.
This means it is no longer required to add the machine kinematics to the post processor script.
Moving forward, using machine definitions in Fusion is the preferred method to specify your machine configuration, kinematics and options like home positions, axes limits, TCP settings and more. It is also important to note that this is the only way to utilize machine simulation, as machine simulation does not function with post processor scripts that have embedded kinematics.
For more information on creating or editing machine definitions,
please refer to the Machine Definition in Fusion learning videos
We made significant changes to most of our library milling posts so that they fully support machine configurations as well as machine simulation. We have also added a lot of predefined machines to our machine library, many of them also have full simulation models associated with them.
You can access all available machines directly from within the Fusion machine library or through our online Machine Library.
Of course, you can still define your kinematics in the postprocessor itself.
In earlier versions of the post processors this was possible within the onOpen function.
This has been moved to the defineMachine function in the latest posts which have multi-axis machine support where you can now make your desired adjustments.
Please refer to chapter 8.1.3 Creating a Hardcoded Multi-Axis Machine Configuration in the Post Processor Training Guide for instructions on how to do this.
Note that you can only EITHER use a machine configuration in Fusion OR define the machine within your postprocessor.
When a postprocessor with a hardcoded machine configuration is used together with a machine configuration in Fusion a warning/error will be generated, and the hardcoded configuration will take precedence.
Note that you cannot import latest machine configurations into Inventor CAM and HSMWorks directly.
For post processing purposes you can still make use of these machine configurations by downloading a packaged post from the online Machine Library.
When you click download, the following download dialog will show up. Select For Inventor/HSMWorks.
You can then select the post processor you want to use with that machine configuration.
By clicking download, a *.CPSZ file will get downloaded.
This is a package that contains both the post processor you specified as well as the machine configuration file. This file can be selected directly in the post processing dialog.
If you need assistance, you can ask for help here:
1) Contact your local reseller/ service provider: HSM post adjustments needed? Find your right contact here
2) Ask the community: HSM Post Processor forum
Previous content:
Most of the generic posts have 5 axis capabilities already implemented but disabled by default since it is required to set the right machine configuration for the ABC axis for the specific machine you want to use.
The machine configuration can be found into the onOpen() function:
Step 1:
The very first step is to change (for this example, line 173):
  • if (false) to this: if (true)
to activate the machine configuration code below.
Step 2:
Now you can go ahead and start to customize the ABC axis to your needs with the options as described below:
  1. actuator: Specifies that the actuator type (ie. either "linear" or "rotational").
    The default is "rotational".
  2. table: Specifies that the axis is located in the table or the head. The default is true for table.
  3. axis: Specifies the axis vector as a 3-element array (e.g. "[0, 0, 1]").
    [Axis rotates around X, Axis rotates around Y, Axis rotates around Z]
    Example: A-axis rotating around the X-axis would be this: [1, 0, 0]
  4. offset: Specifies the axis offset as a 3-element array (e.g. "[0, 0, 25]").
    The default is [0, 0, 0].
  5. coordinate: Specifies the coordinate used in the ABC vectors (ie. "X", "Y", or "Z"). The given number will define the letter for the axis:
    0 = “A”
    1 = “B”
    2 = “C”
    Note: This is the only way to influence the axis letter for the output.
  6. cyclic: Specifies that the axis is cyclic. Only supported for rotational axes.
    Only used when a range is specified. The default is false.
  7. range: Specifies the angular range for the axis in degrees as a 2-element array (e.g. "[-120, 120]"). You can also specify a single number to create an axis for an aggregate.
    The default is unbound.
  8. preference: Specifies the preferred angles (-1:negative angles, 0:don't care, and 1:positive angles). The default is don't care.
  9. resolution: Specifies the resolution. In degrees for rotational actuator. The default is 0.
Please note:
If you only need a 4 axis setup, you can either delete the other axis beginning with
"var bAxis” and  “var cAxis” or you can just disable them by typing two slashes “//” in front of the line which you want to disable.
Don´t forget to remove the disabled axis variable out of the code as explained in Step 3.
Step 3:
machineConfiguration = new MachineConfiguration(aAxis, cAxis);
  • This line creates a new machine configuration as defined above by using the given variables for each axis (in that case: aAxis, cAxis).
  • You can only use the variables inside the brackets which are defined above.
Examples:
4 axis setup, A rotates around X, direction is positive:
var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-360,360], preference:1});
machineConfiguration = new MachineConfiguration(aAxis);
4 axis setup, A rotates around X, direction is negative:
var aAxis = createAxis({coordinate:0, table:true, axis:[-1, 0, 0], range:[-360,360], preference:1});
5 axis, B rotates around Y, C rotates around Z, directions both positive:
var bAxis = createAxis({coordinate:0, table:true, axis:[0, 1, 0], range:[-360,360], preference:1});
var cAxis = createAxis({coordinate:0, table:true, axis:[0, 0, 1], range:[-360,360], preference:1});
machineConfiguration = new MachineConfiguration(bAxis, cAxis);
Step 4:
setMachineConfiguration(machineConfiguration);
  • This line enables the machine configuration, no need to change something here.
Step 5:
optimizeMachineAngles2(0); // TCP enabled (eg. M128, TRAORI, G43.4, G243)
optimizeMachineAngles2(1); // TCP disabled (eg. M128, TRAORI, G43.4, G243)
  • With this option you can decide if your machine has TCP capabilities for 5 axis simultaneous machining or not.
Achim.N
Principal Technology Consultant
Replies (56)
Message 21 of 57
Hey jpershing,
I know the DMS post is almost identical to the quintax one I need, especially since yours is turning g48 on.
Is there any chance I could have you send me yours, please?
Thank you,
Zach
Message 22 of 57
I don't have a good one yet. I will when I do
Message 23 of 57
Thanks, jpershing. I'm looking forward to it.
Message 24 of 57
jpershing,
Any luck with your DMS post yet? I've been hacking through my generic Fagor and there are quite a few things that still aren't working.
Message 25 of 57
ci3jk4
Im having some difficulties setting up my machine.
I have started using fusion 360 around one week ago and been using it for a Kimla bpf2030 5d router with an a/c axis on the head.
Problem is that I'm not sure which is the correct post for my machine. For now I have been using Fanuc generic with good results.
I tried to edit it and it kind of works.
When milling a swarf on a hole the problem is that the flute is either miling with its face, or dragging the face over the chamfer, resulting with a round'ish chamfer.
It seems that the A axis should be moving around Y instead of X, or the C axis should have a 90degrees offset...
My setup is:
var useMultiAxisFeatures = false;
function onOpen() {
if (true) { // note: setup your machine here
var aAxis = createAxis({coordinate:0, table:false, axis:[1, 0, 0], range:[-120, 120], preference:0});
var cAxis = createAxis({coordinate:2, table:false, axis:[0, 0, 1], range:[-213, 213], preference:0});
optimizeMachineAngles2(0); // TCP mode
if (!machineConfiguration.isMachineCoordinate(0)) {
aOutput.enable();
if (!machineConfiguration.isMachineCoordinate(1)) {
bOutput.disable();
if (!machineConfiguration.isMachineCoordinate(2)) {
cOutput.enable();
tried changing the tcp mode to 1 as well as setting axis to -[1,0,0] and all other variations, any ideas where should I look now?
Message 26 of 57
scottmoyse
@AchimN wrote:
If you have any problems, you can ask for help here:
1) Contact your local reseller: http://cam.autodesk.com/buy/
2) Ask the community: http://forums.autodesk.com/t5/post-processors/bd-p/218
@AchimN Could you update the local reseller link to this please, since that one doesn't work anymore? https://forums.autodesk.com/t5/hsm-post-processor-forum/hsm-post-adjustments-needed-find-your-right-...
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 27 of 57
CCarreiras
HI!
Now my post is able to output based in G43,4 and (A,C) coordinates.
But, the machine (Robodrill post) needs to read "P" function.
How can i turn on this?
Example Code:
000000
G21
G00G17G40G49G52G80G90G69
G91G28Z0.
G90
T2M6
G90G54
G0X3.017Y-28.248A0C0
S17000M03
(/M21)
(/M22)
G00 G43.4 L1  P3 H2 Z-17.74
G01A-34.333C101.419F30000
G01X2.91Y-26.861F15000
X2.853Y-26.786
X2.793Y-26.706
X2.307Y-26.064
X2.241Y-25.992Z-17.746A-33.901C101.373
X2.175Y-25.919Z-17.753A-33.471C101.366
By now, i have this:
(SWARF1)
N1615 G00 G43.4 X55.604 Y36.302 Z15. H01 (No P instructions)
N1620 G00 A-335.727 C-130.222
N1625 Z-4.555
N1630 G01 X55.595 Y36.275 Z-4.806 F1000.
N1635 X55.549 Y36.211 Z-5.045
Thank you.
CCarreiras
Message 28 of 57
WallaceLau
Has the question of "B axis rotate under 45 degrees" been answered?  It's the first reply to this thread, but it looks to have been skipped over (while other questions have been addressed).  The older DMG DMU have their "B" axis rotation flange mounted at 45 degrees, but if you issue G7 commands it will move both the B/C axis to correctly angle the plane, and then compensate X/Y movement to work with the unorthodox kinematic.  However the generic Millplus PP doesn't seem to work correctly with this setup.
Thanks in advance for the assist!
W.
Message 29 of 57
dudukovic_goran
Hello...can some one help!?
Its old maho machine with 4 axis and philips 432 , B axis around y
I try edit post es it explame in frst post , but no luck
I know that this machine have reverse axis y/z, but I use b axis only when set up machine in vertikal setup, so then is regular xyz orientation
This is what I do, and what I have frop pp is error that toll orientation is not support!
Message 30 of 57
rcrdesign
Thank you - your post solved my issue (G68.2)... Definitely needs to be mentioned, only if I saw this earlier. Yahoo
Message 31 of 57
Re: How to set up a 4/5 axis machine configuration
I have a wabeco milling machine with a wabeco 2 axis rotary table."
Hi, did you get the offset sorted out because I am in the same situation after making my AB axis addition.
Rgeards Colin Wood
Message 32 of 57
I have a PilotPro 5 axis.
I have the 5axisMaker post and I need to edit it for my B Head C Table setup.
I want to limit the rotation of the B Head, CW.
~original~
    var bAxis = createAxis({coordinate:1, table:false, axis:[1, 0, 0], range:[-180.00, 180.00]});
    var cAxis = createAxis({coordinate:2, table:false, axis:[0, 0, 1], offset:[cAxisOffset, 0, 0], range:[-360.00, 360.00], cyclic:false});
~my edit~
    var bAxis = createAxis({coordinate:1, table:false, axis:[1, 0, 0], range:[-5.00, 100.00], preference:1});
    var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], offset:[cAxisOffset, 0, 0, 0], range:[-360.00, 360.00], cyclic:false, preference:1});
Should I turn Off TCP?
I have no Jave Script karate skills, so I hope somebody can let me know if I got this correct.
Thank you
Message 33 of 57
Also,
My C Table is a Sherline Rotary and can be continuous, but if I understand Fusion360, it is not, correct?
So do I want to set range to:
var cAxis.......range:[-360.00, 360.00]
var cAxis.......range:[-999.00, 999.00]
or remove it from text so it is the default, Unbound?
Thank you
Message 34 of 57
FTKnur
When you turn the table are you over 360° or everytime between 0° and 360°?
Haidenhain has the M94 command to change this.
In your PP you can use [0,360].
Edit: I have used the wrong "reply" button - I've replied the last on site 1 😄
Message 35 of 57
Laurens-3DTechDraw
@Anonymous wrote:
Also,
Thank you
You have to set the cyclic command to true.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 36 of 57
Thank you both,
I'm also having trouble with "exploded" paths in Mach3.
I am using a file that worked successfully on the PocketNC using the PocketNC post processor in Generic.
Its a 3+2 solution on their 5 axis table on table unit.
When using the 5axisMaker PostProcessor with the original edits above, a group of Four paths, that are part of a Pattern, repeating every 90degrees, will "explode" away from the object center on all axis in a non uniform manner.
Loading the older PocketNC file that were successful, yielded incorrect orientation and stacking of all four paths that were in the Pattern.
I have no idea where to even start looking.
Message 37 of 57
Thanks for the great info!
I am editing the mazak post to support our 5 axis (B and C) machine.
Here is what I have so far BUT I still get a axis code when I post.
What am I missing?
var bAxis = createAxis({coordinate:1, table:true, axis:[0, 1, 0], range:[-190, 20], preference:-1});
var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[-360, 360], preference:1});
optimizeMachineAngles2(1); // TCP mode
aOutput.disable();
bOutput.disable();
cOutput.disable();
Thank you for the help
Message 38 of 57
splintWFYFX
I' trying to modify the generic mach3mill.cps post for a table/table machine with b tilting about y and c rotating about z.
In step 1 it references the onopen function which needs to be changes from false to true,  the only time in this post onopen appears the syntax is substantially different from what post processor training guide indicates, no true false option that I can see, no range option. Can you please advise on how to go about this? Screen shot attached.
Message 39 of 57
Not sure if you have found this in the forum. Here is a great page to read.
https://forums.autodesk.com/t5/hsm-post-processor-forum/how-to-set-up-a-4-5-axis-machine-configurati...
I see it has changed a bit.
Here is my suggestion
function onOpen() {
if (properties.useRadius) {
maximumCircularSweep = toRad(90); // avoid potential center calculation errors for CNC
// My edits here
// You can put is range as in website above explained
// the offsets were not working, not sure if they do now
if (true) {
var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], preference:0});
var bAxis = createAxis({coordinate:1, table:true, axis:[0, 1, 0], preference:0});
machineConfiguration = new MachineConfiguration(aAxis, bAxis);
optimizeMachineAngles2(1); // 0= Enabled, 1=disabled TCP enabled (eg. M128, TRAORI, G43.4, G243)
// No edits below here
aOutput.disable();
bOutput.disable();
cOutput.disable();
if (!properties.separateWordsWithSpace) {
setWordSeparator("");
sequenceNumber = properties.sequenceNumberStart;
if (programName) {
writeComment(programName);
if (programComment) {
writeComment(programComment);
Any thing else don’t hesitate to contact me.
Regards
Colin
Message 40 of 57
splintWFYFX
Thanks Colin,
That's definitely a step in the right direction. I did modify the code as you indicated but substituted the values a and b for b and c as it is tilting around y and rotating around z not x and z.
The post processor does produce 5 axis code that Mach 3 will run (run only on the software at this stage with the machine not connected) but it produces a and b rather than b and c.
I did a little extra modification to the code because it looked like the pp was set for fourth axis only, not sure if it was required but it doesn't appear to do any harm. The code changes are as follows:
Line 55: fourthAxisAround: "none", // specifies the fourth axis if mounted
Added the following in line 56: fifthAxisAround: "none", // specifies the fifth axis if mounted
Line 71 contains references to both x and y, I’m unclear on how this works: fourthAxisAround: {title:"Fourth axis mounted along", description:"Specifies which axis the fourth axis is mounted on.", type:"enum", values:[{id:"none", title:"None"}, {id:"x", title:"Along X"}, {id:"y", title:"Along Y"}]},
Added the following in line 72: fifthAxisAround: {title:"Fifth axis mounted along", description:"Specifies which axis the fifth axis is mounted on.", type:"enum", values:[{id:"none", title:"None"}, {id:"Y", title:"Along Y"}, {id:"Z", title:"Along Z"}]},
Added the following immediately after the onopen statement:
var cAxis = createAxis({coordinate:0, table:true, axis:[0, 0, 1], preference:0});
I'm not a coder so I could be way off with this. Any idea how to get the post making bc rather than ab code?
David
