Program End Code Changes
I am running a Fanuc Oi-MB control on a Leadwell v-50.
Because of the position of the vice and the travel of the table, when I finish a part, it runs the table to the X0 Y0 position which is tucked away in the corner and unreachable.
For now I have been adding a rapid movement command to shift the table so that it is in front of the door, but I would like for the post processor to do this automatically and have the table move in front of the door on it's own.
What do I needed to do to the post processor for these changes to be made?
For reference I want the table to move to X30. Y0
Byron Hameline
YOu can hard code the end position into your post if you never plan to have it change.
It can also be made as a user-selectable property in your post as well.
Final option would be to use a machine configuration that sets your home position.
Your post may be setup already for this option.  To test, select a machine configuration in HSMworks that has a home position defined in it.
If you want one of the first two options, upload your post here and I should be able to make a change for you..
Steve
Here is the post config I am using.
If you could make the changes and then tell me what you wrote in and where you wrote it that would be very helpful.
Byron
Give this a shot:
I added two user defined properties that you can change when posting.
I made these post out in machine coordinates (G53 X30. Y0.).  Let me know if that needs to change.
You can find the changes I made by searching for my initials in the comments : SAP
Obviously, please test carefully before running.
Steve
Thanks!
