HSM Post Processor Forum
How to avoid post-processing an optional operation?
1 REPLY 1
ateliercnc3d
221 Views, 1 Reply
Hello!
I'm using HSMXpress and I have a job with different operations. Some of them I like to mark as Optional and avoid to be post-processed, when I choose RMB -> PostProcess(All) on the job stock.
What modifications I have to make to the postprocessor file in order to skip the operations marked as Optional?
Could someone indicate a simple post file example dedicated for skipped Optional operations?
1 REPLY 1
Hello @ateliercnc3d
initially the Optional operation was not defined for this usage.
The actual behavior of the optional is as follow :
The first operation is set as "normal", and the second one as "Optional":
N60 G0 Z5.
N65 G1 Z-1. F1000.
N70 X-80.
N75 G2 Y0.95 I0. J12.663
N80 G1 X80.
N85 G0 Z15.
N90 M1
/ N95 M9
/ N100 M5
/ N105 G53 G0 Z0.
(2D-Contour)
/ N110 M1
/ N115 T2 M6
/ N120 S6000 M3
/ N125 G54
/ N130 M8
/ N135 G1 X-9.725 Y36.25 F650.
/ N140 G0 G43 Z15. H2
/ N145 T3
/ N150 G0 Z5.
Please not the / sign in front of the line.
On controllers we can have a switch (software or hardware) for running or not the optionnal blocks.
If you want to remove the outputcompletely, the writeBlock function can be modified.
The changes I will show will be ok on a 3 axis milling machine.
But don't use it for a multi axis machine, i will explain later below.
Imagine the initial writeBlock is as follow:
function writeBlock() {
  var text = formatWords(arguments);
  if (!text) {
    return;
  if (getProperty("showSequenceNumbers")) {
    if (optionalSection || skipBlock) {
      if (text) {
        writeWords("/", "N" + sequenceNumber, text);
    } else {
      writeWords2("N" + sequenceNumber, arguments);
    sequenceNumber += getProperty("sequenceNumberIncrement");
  } else {
      writeWords2("/", arguments);
    } else {
      writeWords(arguments);
  skipBlock = false;
We will change it to
  if (!text) {
    return;
    if (optionalSection) {  // do nothing
    } else if (skipBlock) {
      if (text) {
    } else {
  } else {
    } else {
  skipBlock = false;
Why not using it on a multi axis post?
N85 G0 Z15.
N90 M1
/ N91 G69		//workplane cancellation in 3+2 for example
/ N95 M9			// En of operation that will be suppressed by the Fix
/ N100 M5
/ N105 G53 G0 Z0.
(2D-Contour)
/ N110 M1
/ N115 T2 M6
/ N120 S6000 M3
Bunch of line ine thes middle suppressed for concision
/ N340 G0 Z15.
			// no G69 here as the operation may be in 3 axis only
N345 M9			// end code of the second operation that will be used as end of the first one.
N350 M5
N355 G53 G0 Z0.
(2D-Contour with compensation left)
N360 M1
N365 T3 M6		// potential crash after that as the tilted workplane may still be active
Have a nice day.
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
