Help with M8 and M9 code in fagor postprocessor
torABLHW
Message 1 of 10
torABLHW
Hi
I want help to add coolant code to the attached Fagor postprocessor, it generate the machine code ok, but with out the M8 and M9 code.
I will be very happy if somebody can help me.
Kind regards
 Torben
Replies (9)
Message 2 of 10
CNC_Lee
@torABLHW
If the generic posts are not providing the required output, I offer post processor development services and happy to work out a solution for your machine! Please message me if I can be of any assistance.
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
Message 3 of 10
andrea.amilo
Hello @torABLHW ,
I have noticed that the postprocessor you are using is really outdated, it looks like 2014!
I would suggest you to update it, just download the latest version from the post library.
Having said that, I have tried to modify it to suit your needs.
Please try to do what I show you below:
1.
2.
Please test it carefully and let me know.
Thanks.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
Message 4 of 10
torABLHW
Hi
I use Inventor cam 2016, can i use all postprocessor versions ?
Kind regards
Torben
Message 5 of 10
torABLHW
Hi
Message 6 of 10
andrea.amilo
Hello @torABLHW ,
if you are using a 2016 version, you will not be able to use the latest versions.
You can search through the previous versions of the postprocessor:
In the meantime, have you tried the modifications I suggested?
Please let me know.
Thanks.
Andrea Amilo
Message 7 of 10
torABLHW
Thanks  andrea.amilo
That works so all seems to work well now.
Best regards
Torben
Message 8 of 10
torABLHW
Ohhh now i have an error as seen on the picture.
I seems to have something to do with G18.
I tried earlier to disable it from the postprocessor and then the error don't come again, so that could be ok.
But maybe it is better to locate why it make an error with G18 and the use the G17, G18 and G19 funktions, there mus be a reason why they ar defined in the post.
Best regards
Torben
Message 9 of 10
andrea.amilo
Hello @torABLHW ,
you can try to modify the 'allowedCircularPlanes' command as shown below:
'1' means that your postprocessor will handle circular moves only on G17 plane.
Thanks.
Andrea Amilo
Message 10 of 10
torABLHW
Yes i tried the modifications you suggested, and that works well, thank a lot. 🙂
