Hi all
Probably an easy one as far as you guys are concerned but, being a post-processor novice, I was wondering if it's possible to remove the following code before outputting?
CYCL DEF 32.0 TOLERANCE
CYCL DEF 32.1
The machine operator says it's causing issues and for a quick fix could it be done?
Solved by Tomek.G. Go to Solution.
Hi @Stephen__Hall ,
The simplest way is to add "return;" at the begining of setTolerance() function (line416 in heidenhain.cps).
function setTolerance(tolerance) { return;
Then the rest of the function will not be executed.
