Hello Every one,
I am very new to this but very old .. lol. I had to have a change of direction in my life due to a stroke, I was hoping that getting a CNC and relearning something new would help grow brain cells back, my problem is that I should have thought more on getting a machine, well support really, as I can't find a Post Prosseccor, that works where to get one even wrote to the people that make the DSP A18 so if there is anyone that could help, In very simple terms please, I also have a rotary attachment that runs along the Y.
Thank you for your time in this matter
Ian
Hi Ian,
I assume you are using HSM software for the programming.
Check if it is using a Mach3 control software. There is a post for it in the post library:
https://cam.autodesk.com/hsmposts
Search for Mach3Mill. Somebody uploaded a 4 axis post for Mach3 a while ago. This should get you started.
Cheers
Attila
I am using Fusion 360 to make design, don't know what to export file as so that the DSP A18 controller will understand the g code
