haas post issues
haas post issues
haas post issues
I downloaded and installed the latest post for haas with a axis. No matter what i try to post I get this fail page.
Information: Configuration: HAAS - A-axis (pre-NGC)
Information: Vendor: Haas Automation
Information: Posting intermediate data to 'C:\Users\Terry\AppData\Local\Fusion 360 CAM\nc\1006.nc.failed'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Thursday, October 19, 2017 5:29:25 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41684
Configuration path: C:\Users\Terry\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts\haas with a-axis (1).cps
Include paths: C:\Users\Terry\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts
Configuration modification date: Thursday, October 19, 2017 5:04:38 AM
Output path: C:\Users\Terry\AppData\Local\Fusion 360 CAM\nc\1006.nc.failed
Checksum of intermediate NC data: 6dffbb9b1669b49b75be990378267f88
Checksum of configuration: 64137d954c57d4c7cf47f3f1b09ce623
Vendor url: https://www.haascnc.com
Legal: Copyright (C) 2012-2017 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.3620
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Error: Direction is not supported for machine configuration.
Stack dump:
("Direction is not supported for machine configuration.")@:0
getWorkPlaneMachineABC([object Matrix])@C:\Users\Terry\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts\haas with a-axis (1).cps:887
defineWorkPlane([object Section],true)@C:\Users\Terry\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts\haas with a-axis (1).cps:837
onSection()@C:\Users\Terry\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts\haas with a-axis (1).cps:1409
Failed while processing onSection() for record 594.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Thursday, October 19, 2017 5:29:25 AM
Post processing failed.
I am at a total loss as to why this doesn't work. Thanks for any reply
Last attempt was drill hole index 90 drill same hole.
Laurens-3DTechDraw
@Anonymous
Could you attach the part?
I think the post is setup with the A-Axis revolving around X not sure if that is also what happens on you part.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
