Haas MiniMill Post output Error
Eli_Dexter
Message 1 of 10
Eli_Dexter
I have just got new Hass MiniMill machine, downloaded Post for Hass (tried NGC, Pre-NGC, and some other) and trying to post. 1st thing I have noticed Program Settings is all blank.
When I click Post, I am getting error message:
Error: Failed to evaluate post configuration.
Loading locale from 'C:\Program Files\HSMWorks\locales\english_us.xml'
Code page changed to '1252 (ANSI - Latin I)'
Start time: Thursday, December 12, 2024 8:33:08 PM
Code page changed to '20127 (US-ASCII)'
Warning: Unsupported format specifier 'minDigitsLeft'.
Error: ReferenceError: FORMAT_REAL is not defined
Error at line: 296
Stack dump:
@K:\Engineering\ACAD\SolidWorks\SSDI Library\HSMXpress\haas.cps:295
Failed while processing global script.
Is there a problem with post or I am doing something wrong? I have used other posts (for different machines) and they are fine...
Replies (9)
Message 2 of 10
CNC_Lee
@Eli_Dexter
Can you share the file that you are getting the error with?
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
Message 3 of 10
Eli_Dexter
Here you are... But I do not believe the issue is in the file. I had another file that gave me the same error.
Message 4 of 10
CNC_Lee
@Eli_Dexter
Got you!
I was more so looking for the CAM related information in the file.
Please store your toolpaths using the "Save as Template" function and attach a copy of that as well.
CNC Lee
Message 5 of 10
Eli_Dexter
See Attached. I had to rename the file to .xml - otherwise I would not be abple to attach it. Please download and rename it to .hsmworks-template.
Message 6 of 10
Eli_Dexter
I still did not get any replies to my las post.
Any ideas?
Message 7 of 10
pcookS62QK
I'm running into a similar problem, albeit with a different post.
I have a ShopSabre CNC, and have been able to post things without issue for a while now. But now, for some reason, I'm having very similar symptoms to what OP had: The Program Settings are blank; the NC extension has changed and is not longer what it used to be (used to be .tap, now is .nc); and when I try to post I get a log with a similar error:
Start time: Monday, January 27, 2025 6:41:12 PM
Error at line: 153
Stack dump:
@\\diskstation5wp1\Badlands\Peter C\CNC Files\shopsabre.cps:152
Again, I've been using the same post for a while, have not changed the post file, but now I'm getting this error when trying to post.
Has anyone had any luck figuring this out?
Message 8 of 10
boopathi.sivakumar
Hi @Eli_Dexter @pcookS62QK
The reson may be because of the you are using the old version of HSM works or Inventor CAM. If possible pls try to update it to the latest version.
else you can try old revision of post from our library to use
Boopathi Sivakumar
Senior Technology Consultant
Message 9 of 10
Eli_Dexter
Fortunately, there are many Haas posts out there and I have found one that works without errors.
Message 10 of 10
pcookS62QK
Hi @boopathi.sivakumar,
I've tried using the updated post from the link you shared, with no change in results. Also, I cannot update to a newer version of Inventor CAM, as the 2023 version is what the rest of my company uses. The confusing part is I was able to do things just fine, but for some reason something changed and now I cannot. And I don't know what that change was.
