HSM Post Processor Forum
Generic Anilam Conversational post
15 REPLIES 15
Message 1 of 16
fonsecr
3778 Views, 15 Replies
Here is a generic post for the Anilam Conversational format.
Let me know if you find any issues.
Code looks like this:
* TOOL 2  D=6 CR=3 - ZMIN=10 - BALL END MILL
Dim Abs
Plane XY
Unit MM
Rapid Z0 Tool# 0
* CONTOUR1 BALL NO FILTER
M9
Tool# 2
RPM 5000 M3
Offset Fixture# 0
M8
Rapid X -56.25 Y -40.079 Z 60
Rapid Z 40.709
Line Z 40.698 Feed 500
Line X -56.252 Y -40.078 Z 40.651
Line X -56.256 Y -40.074 Z 40.604
Line X -56.263 Y -40.068 Z 40.558
Plane XY
Arc Ccw X -56.272 Y -40.06 Z 40.513 I -56.749 J -40.639
René Fonseca
Software Architect
15 REPLIES 15
Message 2 of 16
in reply to: fonsecr
can i use this on a anilam 6000 touch it has true conversational but i run the .g programs
Message 3 of 16
fonsecr
I sent you a generic Anilam ISO post also you can try.
René Fonseca
Software Architect
Message 4 of 16
Any chance you guys are or  will be working on a Mazak Mazatrol conversatinal format post?
Message 5 of 16
fonsecr
No not really. This format is binary and undocumented.
René Fonseca
Software Architect
Message 6 of 16
I have a hybridized version of this generic Anilam post script (.CPS) that I've altered to run on our Anilam 3000MK.  It still needs a little cleanup, but is working well for us.  If anyone has interest in it, let me know...
Message 7 of 16
Jason, I would like to try your .CPS file. Can you post it please?
Message 8 of 16
I've attached the current file I'm using.  It's still a little rough, and not everything has been tested, but it works for us.  We are running it on a 3 axis Chevalier vertical mill.  The file heading lists the changes. Let me know if you find any issues with it.
Message 9 of 16
We have an Anilam 5300MK contoler on our machine, and the Generic Anilam Post has several Syntax errors.
I will try this 3000MK post and see how it goes. Has anyone modified a post for the 5300MK?
Message 10 of 16
May I get a copy of the post, please?
Message 11 of 16
This is an old post, but you replied directly to someone with a 6000i machine.
We have the same machine, can you point me to the correct post processor for it, you forwarded it to him in your reply I believe.
Message 12 of 16
Hi, I am also interested in the 6000i post, have you had any luck finding one?
Message 13 of 16
No, no reply, but the thread is 5 years old.
Message 14 of 16
Thanks for the reply, I though you might have gotten a email.  Have you tried editing any other posts yourself, I have seen other threads with 6000M and 5000M posts
Message 15 of 16
We haven't gotten that far. We are still learning the software and working with Fab to get the appropriate settings into the machine to make some sample code to try.
We are going to attempt the generic Anilam ISO first and see how it works. Have you attempted any parts on the machine through HSM?
Message 16 of 16
We have been using fusion for a couple months now, mostly CAD but it has CAM capabilities that we want to use as well. I just started looking into posts today but I have seen the generic anilam ISO so I think it'll be a good starting point. Also as I mentioned, there are a few 6000m posts going around so I'll take a look at those as well. Will make updates once we have it running
Technology Administrators
