* TOOL 2 D=6 CR=3 - ZMIN=10 - BALL END MILL
Dim Abs
Plane XY
Unit MM
Rapid Z0 Tool# 0
* CONTOUR1 BALL NO FILTER
M9
Tool# 2
RPM 5000 M3
Offset Fixture# 0
M8
Rapid X -56.25 Y -40.079 Z 60
Rapid Z 40.709
Line Z 40.698 Feed 500
Line X -56.252 Y -40.078 Z 40.651
Line X -56.256 Y -40.074 Z 40.604
Line X -56.263 Y -40.068 Z 40.558
Plane XY
Arc Ccw X -56.272 Y -40.06 Z 40.513 I -56.749 J -40.639
Jason Bonser wrote:
I have a hybridized version of this generic Anilam post script (.CPS) that I've altered to run on our Anilam 3000MK. It still needs a little cleanup, but is working well for us. If anyone has interest in it, let me know...
This is an old post, but you replied directly to someone with a 6000i machine.
We have the same machine, can you point me to the correct post processor for it, you forwarded it to him in your reply I believe.
Thanks for the reply, I though you might have gotten a email. Have you tried editing any other posts yourself, I have seen other threads with 6000M and 5000M posts
We have been using fusion for a couple months now, mostly CAD but it has CAM capabilities that we want to use as well. I just started looking into posts today but I have seen the generic anilam ISO so I think it'll be a good starting point. Also as I mentioned, there are a few 6000m posts going around so I'll take a look at those as well. Will make updates once we have it running
