HSM Post Processor Forum
G2 move has too much error
14 REPLIES 14
Message 1 of 15
SGoldthwaite
1772 Views, 14 Replies
I'm making a spur gear on my Shapeoko which uses a gShield board with GRBL firmware.  GRBL generates an error if a G2 or G3 command has more then 0.005" error.  GRBL is giving me this error for some gcode that Fusion 360 is generating.  You can find the Gcode here: http://pastebin.com/G6Ep09Ry.  Line 56 is the one causing a problem.
The error for this move is: 0.005007"
The post processor I'm using is a modification of generic grbl.  The modifications I made are not related to how it calculates G2 or G3 commands.
I attached my Fusion360 file.  The operation that generates this gcode is called "Teeth Finish"
I also attached the spreadsheet I used to calculate the error.
Are there some settings I can change to reduce the calculated error so it's less then 0.005"?
14 REPLIES 14
Message 2 of 15
SGoldthwaite
in reply to: SGoldthwaite
Achim
I saw you posted a solution, but now it's gone.  Did you delete your post?
Message 3 of 15
AchimN
Jep, the code i posted wasn´t working for your issue, working on it now  😉
Achim.N
Principal Technology Consultant
Message 4 of 15
AchimN
try this code in onCircular please:
  var radius= Math.sqrt(Math.pow(xyzFormat.format(cx - start.x), 2) + Math.pow(xyzFormat.format(cy - start.y), 2));
  var error= Math.abs(Math.sqrt(Math.pow(xyzFormat.format(x) - xyzFormat.format(cx), 2) + Math.pow(xyzFormat.format(y) - xyzFormat.format(cy), 2)) - radius) /radius;
  if (getCircularPlane() == PLANE_XY) {
    if (error > toPreciseUnit(0.0049, IN)) {
      linearize(tolerance);
      return;
This will only work for XY arcs, what about YZ, ZX arcs?
Let me know if it is working.
Achim.N
Message 5 of 15
SGoldthwaite
The post failed (see attached).
I'm only doing x-y arcs right now, but I do want to do some 3D stuff in the future.
Message 6 of 15
AchimN
The code was only into the wrong place into your post, thats why it failed, try this one please.
Achim.N
Message 7 of 15
Achim,
Where does this error come from?
Is the data from the system wrong or is the post just not using the info correctly?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 8 of 15
AchimN
What i´ve seen yesterday is that this is only because of rounding. When I use the values without any formats the error is something like 0,000004532, so nearly nothing. Another question, linuxcnc also supports radius format for G2/3 which is often the better choise to avoid exactly those issues. Did anyone try this on a linuxcnc?
Achim.N
Message 9 of 15
Got ya!
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 10 of 15
SGoldthwaite
It's working now.  I even generated some gcode that was causing an error on GRBL and it's ran fine.  Thanks!
Message 11 of 15
AchimN
Ok perfect, thanks for the feedback. This code will be included in the generic post for future releases.
Achim.N
Message 12 of 15
fonsecr
I just looked at this example. And the error for the move you list is only 0.0002" which is well below then your 0.005" limit. So not sure why your CNC control would error out for this case. Since 4 decimals are used you can expect a maximum error around 0.0002" when coordinates are rounded up and down, respectively.
Maybe the CNC is actually failing for a different move?
René
René Fonseca
Software Architect
Message 13 of 15
SGoldthwaite
Did you look at the spreadsheet with the calculation that's in the original post?
Message 14 of 15
I just put it all in a SW sketch and the biggest error in those value's I can find is 0.0006.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 15 of 15
fonsecr
Yes, I used your spreadsheet. Just removed your divide by radius to get the error in inches.
René
René Fonseca
Software Architect
