I have a post that I got really close, but i am not sure how to add a unclamp(M111) before the "B"(rotary) axis position and a clamp (M111) after rotary position. if someone one can point me in the right direction that would be helpful.
Solved by KrupalVala. Go to Solution.
HI @JOEWCG82 ,
Please refer to the Syntec post processor, where you will find the 'useClampCodes' post properties. Additionally, take a look into the 'onCommand(command)' function, where we have added command cases for 'COMMAND_LOCK_MULTI_AXIS' and 'COMMAND_UNLOCK_MULTI_AXIS'. You can implement these in your post processor.
hello,
I finally had time to work on this post, when i added the 'COMMAND_LOCK_MULTI_AXIS' and 'COMMAND_UNLOCK_MULTI_AXIS'. to the post it becomes invailed. i attached the post can you let me know where i went wrong?
Hi @JOEWCG82 ,
Please define an mClampModal
variable in your post processor as follows:
var mClampModal = createModalGroup(
{strict:false},
[10, 11], // 4th axis clamp / unclamp
[110, 111] // 5th axis clamp / unclamp
mFormat
Remove the command from following location. There is no use of it.
Regarding the correction of the axis rotation direction, B axis should rotate around the Y axis, you can update the axis
parameter as follows: axis:[0, 1, 0],
