Announcements
What post should be used with a VMX60swi Milling machine?
72744
Observer
72744
Observer
Observer
The company I currently work for just recently bought a VMX60 SWI Hurco milling machine that uses winmax 10 or 11. Im used to running fusion 360 for Haas controllers but not the Hurco. I have a Program in fusion 360 ready to go just not sure which post to use. Which Post would work for this machine? All I see are Generic, Old and mill turn posts but none specific to the VMX60 SWI which I find odd because its a newer model. Thank you for any help!
serge.quiblier
Hi @72744
I suggest using the hurco.cps post.
In order to provide the kinematic definition, assign this machine configuration file, in the setup:
Assign the machine configuration by editing the setup.
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
Observer
Observer
Wow I didn't even see that I don't normally go that route. That works great! I really appreciate you taking the time to help me out! Thank you (:
