Editing Post Possessor FANUC - Inverse Time and A-axis
syafiqfarhan
syafiqfarhan
Can I know how to edit this post-processor?
Currently, I'm using FANUC - Inverse Time and A-axis
I planned to change Y to Z and Z to Y in post-processor
Need to change left to right.
Thank you
boopathi.sivakumar
Hi @syafiqfarhan
By default tcp set for the 4 axis post is set to Non-Rtcp also all the points will be calculated form the local workplane
if you want to set it form the setup workplane
you can edit the post and set it like below
  if (rotate) {
    var tcp = true;   // << make this as true
    if (tcp) {
      setRotation(W); // TCP mode
    } else {
save the post and test it carefully it will make the co-ordinates calculate from the setup origin
let me know the feedback
Boopathi Sivakumar
Principal Technology Consultant
