Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Laurens-3DTechDraw wrote:
Are you sure you don't want your machine to retract at all?
I left the M26 when the program is done, you can probably see how I stopped to others so if you want that out you can probably do it yourself.
Didn't change anything to the cycles. But going to bed now. It's late enough already.
Laurens Wijnschenk
3DTechDraw
René for Legend.
So you need the depth for the Z value?
Look at line 528 of this post, I explained there what you would want to try.
I cannot try for you since I don't have the part.
Laurens Wijnschenk
3DTechDraw
René for Legend.
hello all,
I have an old chinese CNC 4-axis router and it has a Syntec 6MB controller which i can't use autodesk fusion360 for.
I have created a .txt file of the post processor but i need it turned into a .cps file so i can use for fusion360, how can i do that? Can any one help please ?
I found something at this Page.
https://marketplace.visualstudio.com/items?itemName=Autodesk.hsm-post-processor
Using Visual Studio you will change your HSM code and Save it as an HSM extension.
Check out this page and Follow Instructions.
Hope this will solve the issue.
