CSV Setup sheet, how to output "Links"
tobias.nordebrink
Message 1 of 10
tobias.nordebrink
Hi!
Trying to modify the  "tool-sheet-csv" post.
Im having trouble getting these to output anything at all. Tried different .formats, but nothing.
tool.productLink
tool.holderProductLink
Im gonna output other info then weblinks in these boxes.
What am I doing wrong?
Replies (9)
Message 2 of 10
tobias.nordebrink
Found the solution myself! 😲😲
var productLink = getSectionParameterForTool(tool, "operation:tool_productLink");
Message 3 of 10
jonathanBUCVS
Do you have a copy of the getSectionParameterForTool function? Its not in my setup sheet post. I am trying to do the same as you, pull in the ProductLink field.
Message 4 of 10
tobias.nordebrink
Have a look in the post I made. It's not finished. But it works. 🙂
Message 5 of 10
jonathanBUCVS
Thank you! That worked. Did you write your post from scratch? It is very different than the one I have been relentlessly editing lol.
Message 6 of 10
tobias.nordebrink
Haha god no. I used a older version of the Tool sheet CSV and just modified it to do what I needed.
Hope its makes things a little easier for you. It was a pain for me to figure out. 😄
Message 7 of 10
jonathanBUCVS
I was really stumped by this one, but Ive got it looking good now, thanks to your code! I feel like productLink should not be a global parameter, I guess they never expected anyone to have to output it. I am hoping Autodesk makes some extra user documentation fields when they update the lathe tool library.
Message 8 of 10
CuttingEdgeManufacturing
so product link cant be accessed by a setup sheet like any other tool field?
i just add this line into my setupsheet post?
care to explain usage?
Message 9 of 10
jonathanBUCVS
Edit: Correct, it is not accessed the same way the other tool fields are.
Probably not. The code Tobias provided helped me to modify my post, but it was not copy-paste. I looked at the structure and logic of his functions and adapted them to fit my specific post.
I am using the field for additional tool data. Essentially as a blank text field where I can enter any information. I needed more information than the default fields provided, so I commandeered that field.
Message 10 of 10
neat. I use product link to post a serial number to my setup sheets that is a barcode so setup guys can scan tools in and out of a custom software im working on for tooling inventory.
