Autodesk HSM Post Editor for Visual Studio Code goes live
fonsecr
Alumni Alumni
Message 1 of 136
fonsecr
Hi all post developers,
We just pushed Autodesk HSM Post Editor for Visual Studio Code live as an Open Source project under the MIT license. Check it out at:
https://github.com/Autodesk/cam-posteditor
This project is an extension for Visual Studio Code that makes life much easier when developing posts.
You can get the installation for Visual Studio Code at:
https://marketplace.visualstudio.com/items?itemName=Autodesk.hsm-post-processor
@GeorgeRoberts has been working on this until now. But my hope is that we can work together as a community to make it even better. So if you are interested in contributing make sure to engage. Of course you are welcome to just make requests for the post team also. You can use the post idea station for such requests.
Note that you need to sign a small agreement before we can accept contributions.See the README for details.
George will post introduction to the extension here.
René Fonseca
Software Architect
Replies (135)
Message 121 of 136
fonsecr
Try a simple post that just writes a single line of text. To see if it is something in your post. It that doesn't work then you have to check things like folder permissions and file system paths in any settings. I'm not sure what to look for specifically here. But one thing to check is that paths use the same upper/lower case as actual in the file system.
René Fonseca
Software Architect
Message 122 of 136
fredsi
Claytonics, fonsecr,
Thank you for the replies. I will continue troubleshooting. I don't think the problem is path related as a file is created in the proper location every time I post using the export post. The problem is that the file has no code in it. I get the impression that the post engine is not being called even though I pointed the extension at the post location.
Thanks again for your time.
Fred
Message 123 of 136
jonathan.underwood7WQXB
      I have post version 3.5.5 and have gotten the same error as many others: "Running the contributed command: 'HSM.postProcess' failed.".  Unfortunately, this error doesn't give me the option to browse to the post.exe location.
Is there another way around this?
Here's my attempt:  I may be mistaken, but it appears like the location may be stored in a settings.json file in the /res directory.  Unfortunately, that file is empty so I can't explicitly place the path.  I am aware of .json functional purpose, but I don't have enough experience to build the structure from the function that is calling it.
Thanks in advance!
Message 124 of 136
Alecs_Andrei
Hello guys, in this video: https://www.youtube.com/watch?v=4OWT-O4oN8E
at min 03:52 to 04:10, he click on that debuggedfine at line G95 and jumps to postprocesor settings on left. My problem is that two click not work anymore to jump in postprocesor lines.. can someone help me?
In visual studio i checked that settings with "HSMPost Utility: Two Click Line Jumping" and he not working...
Please help me with this, thx in advance!
Message 125 of 136
GeorgeRoberts
Good morning,
Sorry for the delayed response.
When you say "it's not working anymore", does that mean it used to work for you? Can you give me some information on your setup:
- Operating system
- Add-in version
I assume that post-processing is still working within VSCode, it's just the line jumping?
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
Message 126 of 136
Alecs_Andrei
Its ok now, i just fix it.. windows reinstall. Probably was something in windows
Thx.
Message 127 of 136
john543CDWXW
Observer
Observer
Good Morning George or Rene',
I'm experiencing problems with HSM if I press F1 and type HSM nothing happens or go to settings and type HSM I get a JavaScript error. I thought by removing visual studio and reloading it would fix the error but it didn't.
Is there a fix for my problem?
Well I went back in time with revisions and now I have the HSM back but still cannot click on a line in my G-code and jump to the line in the post processor.
thank you
John
PS,
Got the HSM working.
Message 128 of 136
seth.madore
Seth Madore
Message 129 of 136
mac_ito
@GeorgeRoberts hello, I downloaded your add-in, unfortunately I have the impression that it does not work on macOS? Is this normal?
https://apps.autodesk.com/FUSION/en/Detail/Index?id=7510560621924796173&appLang=en&os=Mac
thank you
Capture d’écran 2023-03-06 à 12.24.58.pngCapture d’écran 2023-03-04 à 22.56.11.png
Message 130 of 136
Laurens-3DTechDraw
It's a plugin for Visual Studio Code, not Fusion.
So you won't see any of it in Fusion.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 131 of 136
mac_ito
Message 132 of 136
mikearzell
For anyone who may be encountering an issue I went through:
I followed steps with VSC and Autodesk Post Utility.
However, I kept running into an "Unknown Spawn Error".
This was because I mistakenly had confused setting the location of post executable with the post file (.cps)
Also, I noticed the post executable is no longer called "post exe". Simply "post" with file type application.
Message 133 of 136
chadDCQYX
Does anyone know the location of the "post.exe" file on macOS?
Message 134 of 136
cahustonFPZWB
Bump, any support for Mac?
Looking through the post history the Autodesk team has mentioned many times that they will bring this add-in to mac but after 7 years I'm not seeing any support
Message 135 of 136
andrew.millardCYPQ9
For anyone wanting to find the post utility on Mac, I have a few notes that I created when I installed it - they may help?
1) Install VSCode (download from https://code.visualstudio.com/download)
2) Once installed, on the extensions tab, Search for and Install Autodesk Fusion Post Processor Utility
3) Click on Settings (bottom of side bar) -
4) Click on ‘Extensions’ and then ‘Autodesk Post Utility’
The Post Executable Path needs to be added here –
You will need to use ‘Finder’ and browse to the following directory –
Users/Username/Library/ApplicationSupport/Autodesk/webdeploy/production/7bbcfa8bd731b98100cd66ff03f62542666d03df
The ‘Username’ is what you are logged in as, and the long number at the end of the above path is whatever version of Fusion you have installed gives you this unique folder name.
In that folder you should see ‘AutodeskFusion.app’ – this is where the post executable is.  To be able to use this, you need to open this app as a folder.  Control + Right Click on the app and then select ‘Show Package Contents’
You should then be able to browse to Contents/Libraries/Applications/CAM360/
Optionally, you can add a shortcut to the CAM360 folder to the Favourites sidebar by clicking and dragging (with the COMMAND key depressed to the desired position).  Might be useful if you need to find this again?
Control and Right Click on ‘Post’ and then ‘Get Info’
Highlight and copy (Command + C) the path beginning with users –
Paste into VS Code Settings for Post Location  (make sure ‘/post’ is on the end of the path) –
Restart VS-Code and posting should now be possible.
If my post answers your question, please click the 'Accept Solution' button. This helps everyone find answers more quickly!
Andy Millard
Product Support Specialist
Message 136 of 136
cahustonFPZWB
Huge, this worked. Thank you
