5 Axis post- B & C axis unclamp
Hello-
I am using post: Mazak vc 500 and I need to add a B axis unclamp M code (M46) and a C axis unclamp code (M43) in the post where the b and c axis is used at feedrate moves.
Currently the b and c axis is clamped during 5 axis machining operations, which yields jerky movement.
The machine control automatically re-clamps the B and C axis at the end of each program.
Thank you for the help
Replies (17)
andrea.amilo
Hello @Anonymous ,
I think the Mazak vc 500 post is already configured to manage clamp/unclamp functions.
You can find them commented in onCommand function.
The picture below shows you how I have defined these functions :
Please test it carefully and let me know.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
I see that.
However I dont get any axis unclamp codes when I post.  None at all.
I am currently manually entering them in the code.
What do I need to do specifically to get it to post M46 / M43
Thank you
andrea.amilo
Hello @Anonymous ,
to have the unclamp codes I think you need just to :
- un-comment ( remove // ) lines 2737 and 2740 ;
- add 46 and 43 on the same lines inside existing command writeBlock(mFormat.format()) ;
as shown in my picture above (see message #2).
Please test it carefully let me know.
Andrea Amilo
Ok I will try that.
I am getting an error with C axis rewind.
I have the post configured with c as a cyclic axis.
Here is the error I get when posting:
Error: REWIND: Rewind of machine is required for simultaneous multi-axis toolpath and has been disabled.
Error at line: 2355
I made the edits you suggested BUT I still dont get the unclamp codes when I post a swarf operation.
Here is what I have in the post.
case COMMAND_LOCK_MULTI_AXIS:
if (machineConfiguration.isMultiAxisConfiguration() && (machineConfiguration.getNumberOfAxes() >= 4)) {
var _skipBlock = skipBlock;
writeBlock(mFormat.format(46)); // lock 4th-axis motion
if (machineConfiguration.getNumberOfAxes() == 5) {
skipBlock = _skipBlock;
writeBlock(mFormat.format(43)); // lock 5th-axis motion
Actually, it does post the unclamp codes BUT they are at the end of the program, not before the operation.
andrea.amilo
Hello @Anonymous ,
It seems you made the correct modification in the wrong place.
In fact you edited the    case COMMAND_LOCK_MULTI_AXIS:    as you wrote in message #6.
This part of code is related to the lock commands.
You need to make the same modification in   case COMMAND_UNLOCK_MULTI_AXIS:  as shown in my first reply, message #2.
Andrea Amilo
Ok do I  need to UNDO my first modification (in the wrong place)?
Nevermind on the last question....I am working to locate the lock M codes to insert in the lock section.
Problem here is that it unlocks the B and C axis on every operation....even when they dont need to be unlocked!
@andrea.amilo -
Is there a fix for thix?
andrea.amilo
Hello @Anonymous ,
now you have the standard unclamp/clamp post configuration.
If you want to use unclamp/clamp only in 5 axis machining operations I think you can add :
&& currentSection.isMultiAxis()
in both the 'case' your a managing, as highlighted here ( lines 2725 and 2735 ) :
Andrea Amilo
Thank you.
@andrea.amilo  I do appreciate the help.
We are getting close to having this post worked out.
Next issue is the B axis moves the wrong direction during positional moves.  It moves the correct direction during multi-axis machining moves (swarf).
However, I we just want to use the axis for positioning only....B-90 for example, it moves B positive.
I was working with Bob from autodesk late last week and he helped me fix the multi-axis contour moves and I didnt notice the positional move issue then otherwise I would have asked him to help.
When doing positional moves, (2+3 machining) the b axis doesnt post as a B code but rather I,J,K.
N19 G68.2 X0. Y0. Z0. I180. J90. K90.
N20 G53.1 P1
What do you recommend here?
andrea.amilo
Hello @Anonymous,
your postprocessor is properly configured to use G68.2 function with 3+2 toolpaths.
Based on my Mazak programming knowledge, it could be possibile you need to replace G53.1 P1 with G53.1 P2 in case of B negative orientation. So G53.1 P1 if B positive, G53.1 P2 if B negative.
This is what I've found in a Mazak programming manual:
B. Tool-axis direction control
G53.1 Pp
G53.1: Tool-axis direction control
P: Selection of a solution for the axis of rotation.
0: Processed as “P = 1” or “P = 2”, depending on the construction of the machine.
Works the same as “P = 1” on this machine system.
1: Solution with a positive angle of rotation on the B-axis.
2: Solution with a negative angle of rotation on the B-axis.
You might try to edit manually your nc file to check if this is your machine configuration, too.
If so, we can update your postprocessor.
Andrea Amilo
@andrea.amilo   Yes....the P2 after 53.1 solved the solution.  I am changing this manually.
How do I edit the post to automatically post P2 moves?
Thank you sir
andrea.amilo
Hello @Anonymous ,
I think you need to write B and C preposition values before G68.2 to be able to check the proper B value.
If so, you can activate the useABCPrepositioning option at line 262 :
then you can define your IF statement to check B value, from line 820 to line 824 :
Andrea Amilo
