zFormat is not defined
post processer z format not defined during additive operation. I attached the f3d file and postprocessor FYR. Check it and if required change the post accordingly.
boopathi.sivakumar
@Anonymous
I see the undefined format has been used post processor in the line number 1849
zOutput = createVariable({onchange:function () {retracted = false;}, prefix:"Z"}, zFormat);
you have to change that to
zOutput = createVariable({onchange:function () {retracted = false;}, prefix:"Z"}, xyzFormat);
also same issue also be found in the line number 1858 you have to change that as well
And in the onSectionEnd function
    case "laserPowder":
      if (((getNextSection().strategy.indexOf("ded_") != -1) || (getNextSection().strategy.indexOf("additive_") != -1)) && (!isLastSection())) {
        // do nothing
      } else {
!isLastSection() should come first like below
    case "laserPowder":
      if (!isLastSection() && ((getNextSection().strategy.indexOf("ded_") != -1) || (getNextSection().strategy.indexOf("additive_") != -1))) {
        // do nothing
      } else {
 save and test it
Boopathi Sivakumar
Senior Technology Consultant
