- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have here a part that according to simulation in Inventor-HSM, works very well with the pocket operation and the setting for the fourth axis.
The used post is:
5-axis post for Hermle C12U with a Heidenhain control.
I have attached the program and the posted file to you.
The question is. Does the post generally not support this processing or is there an error?
After the first few movements I aborted the program. Here is a picture of what the milling looks like.
Normally the machine should swivel the C-axis and then swing the whole movements only with the A-axis. If I see this correctly, line 36 will reset the whole thing before the machine calls the subroutine? Then the whole part swings in the A-axis without being twisted in C.
